wkilleffer
I've been trying to remove the exhaust manifold on my 1974 MGB to replace the manifold gasket.
The intake manifold, heat shield, and carbs are off. All the nuts are off all the studs. I've unfastened the manifold from the exhaust pipes.
Trouble is, nothing I've done gives enough clearance to get the manifold off of the last stud that's closest to the back of the car. The manifold wants to hit the steering rod. Otherwise, it would come right off.
Is it ok to cut the tip off that last stud and replace it? I have some extras, but there's always that fear that I won't be able to get the old stud out.
Any ideas or suggestions, including reading the manual, would be welcome.
Thank you,
Thank you,
