Bruce_B
I bought this off of Ebay and the tag that Identifies the carb model is not attached. I know its a HF44 and I'm putting it on a 1275 engine.
Just needed some clarification on what goes where. That the pipe that's horizontal is for the gas feed. The skinny pipe on the diaganol is the overflow for the carb, and the wider pipe on the diagnol is for ?--crankcase. Can I just cap that off?. Also on the manifold is a threaded hole that I can screw a plug in it or does this attach to the
distributor vacuum hose.
questions: where does the distributor vacum hose go? Anyone else using this setup?
Still trying to get some vroom vroom from this engine.
