Pythias
I posted this on the Autox.team.net Spridgets list, and i'll ask you guys too.. i know many are members of both groups, but many are not..
Survey asks...
what kind (BE SPECIFIC.. Brand, Model #, etc) of floor jacks are being used out there...
Father's Day is coming..... ..
i have a small floor jack, but when i push it under the gas tank to reach the diffy, i don't have room to pump the handle.... longer ones, seems that the same thing happens.. when they reach as far as the diffy, the handle is on the ground and can't be pumped... so its either ..drive up on bricks then put the jack under, OR get the axle first from one side, put a jack stand under, then the other side, put another jack stand, then back to the middle raise the whole works and reset the jack stands... isn't there a low profile racing jack or a long jack thin enough to reach ?..
Anyone have experience with this?
https://www.restockit.com/2-Ton-Low-Rider-Floor-Jack-(INT200T).html?source=froogle
Survey asks...
