Fitting New Pistons...........
TonyR
I am about to fit a set of new old stock Hepolite 100M pistons to my BN1,
As the gudgeon pin is an interference type fit in the con rod, should I heat the rods and pistons in an oven to make fitment easier?
If not, what is the trick??
Tony
drambuie
I have done many shrink fits on a number of machine parts....you can freeze the pin as well! I would do both, heat and freeze! I use a preset telescopic gage or inside micrometer to take rough measurements of the heated bores before attempting to drop in the pin or sleeve or what have you! Nothing more fustrating then getting a pin or sleeve stuck in halfway and cocked resulting in egg shaped or warped bore.
I always have a press and v blocks ready just in case i have to square and press the pin or sleeve in. If you are dealing with a size on size or .0005 interfearence fit you really don't need to heat anything, A light table press will work fine, because this is such a light fit....anything .001 and over heat, freeze or both will make things nice and easy! Michael, IL.
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
KVH General Tech Fitting the Pistons and Sleeves--Any TR Triumph 10
S Spitfire Cyl head coolant hose fitting Triumph 1
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Writer2022 GT6 K+N Filter Fitting Triumph 2
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
A Making an A-series engine stand adaptor fitting Spridgets 2
D TR2/3/3A Windshield frame fitting. Triumph 2
B Fitting the Boot Lid Seal Austin Healey 8
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
edkap2002 TR6 lower radiator hose fitting Triumph 2
DerekJ Fitting a 100-Six grille. Austin Healey 10
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
R TR2/3/3A Fitting windshield Triumph 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
D TR2/3/3A front Apron fitting Triumph 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
ckeithjordan TR2/3/3A Oil Fiter Fitting Frustrations Triumph 13
M Fitting a modern radio Austin Healey 9
TulsaFred Convertible Top Fitting problems Spridgets 29
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
TulsaFred Carpet fitting in the Bugeye Spridgets 3
KVH TR4/4A Fitting New Dash--Problem with Dash Pads Triumph 3
PeterK TR4/4A Fitting TWM manifolds for DCOEs Triumph 2
Patrick67BJ8 Poor Fitting New BJ8 Glass Austin Healey 9
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
I Bugeye fuel fitting Spridgets 3
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
H TR2/3/3A Sway bar fitting Triumph 7
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
P Good fitting car cover recommendation? Austin Healey 9
2 TR2/3/3A Fitting mirror against new windscreen Triumph 5
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
