I have a stock 1960 bugeye, 948CC engine. I'd like to replace the mechanical fuel pump with an electric one to improve reliability. I've been looking at the Facet pumps, but I'm not sure which to get. There are two, with back-off pressures of 2-4 PSI and 3-4.5 PSI. (I know, the catalogs are not terribly consistent on what the pressures are, but the Facet website is a bit clearer, and gives these numbers.) My mechanical pump backs off at 3.0 PSI. So, do I get the 2-4 pump and run the risk that it might be near 2 PSI, thus too low, or should I get the 3-4.5 and risk that it might be too high? Or, finally, should I get the 3-4.5 and a regulator? I'd like to avoid using the regulator, since it seems like overkill for this car. Suggestions?
