Facet fuel pump
RETNJ
Member
Bought my chrome bumper '74 MGB a little over a year ago. It has a Facet electric fuel pump installed on the frame just forward of the fuel tank. My question is - how noisy should this pump be? It makes a noticeable clacking sound at any speed.
Is this normal, or a symptom of a failing pump? It looks new, but I believe it was installed in 2004.
Billm
Yes- a Facet runs all of the time and is noisy.
The best fix for this is to mount it on a rubber motor mount type isolator (and add a ground wire) then you won't hear it nearly as much.
It will still last a very long time (even if it is noisy) and is about the most reliable fuel pump available.
BillM
R
RETNJ
Member
You reassured me that the noise is normal so I fabricated a quickie rubber mount to put between it and the frame. It is much quieter now. Will order two 444-080s when I put together my next parts order and do it right. Thanks for the advice.
Bayless How do you mount a Facet fuel pump? Spridgets 10
TulsaFred Airtex vs Facet fuel pump Spridgets 29
drooartz MGB-GT Facet fuel pump location MG 11
AH67 facet fuel pump never stops ticking. Austin Healey 6
Lin Facet Fuel Pump Spridgets 18
R GT6 Facet Fuel Pump Alternative [GT6] Triumph 4
Sebring222 Facet Fuel Pump Other British Cars 9
athenssprite Facet fuel pump - for use on 1960 BE Spridgets 16
healeynut Fuel Pump - Bendix/Facet Austin Healey 0
C Facet fuel pump Austin Healey 6
roofman Facet electric fuel pump - need advice Triumph 15
Sarastro Facet fuel pump question Spridgets 5
aeronca65t Facet, Purolator fuel pump MG 11
drooartz MGB-GT Facet vs SU fuel pumps MG 18
sparkydave Facet fuel pumps reliable? Spridgets 23
steveg Facet pump - explanation for superiority over SU Austin Healey 13
bugedd Facet pump died Spridgets 18
G Facet pumps any good? Spridgets 23
dklawson Metal vs Plastic Facet Pumps ? Spridgets 2
T Normal for a Carter/Facet pump to be hot Triumph 11
healeynut FACET Square Body Pump Woes Austin Healey 4
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 10
A TR6 How many fuel filters-TR6 Triumph 20
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
