Hi all,
When I bought my 67 BJ8 a year ago, it was having overheating problems. It almost never ran below 210 deg. I had the radiator re-cored with a new core with an extra row. I back-flushed the engine, changed the water pump and replaced the american thermostat with a 160 deg sleeved bellows thermostat from Moss. I switched to a 6-blade fan from Moss and replaced the radiator cap with a new 7 lbs. cap. I also checked the temperature guage for accuracy.
After all of that, the car would run at 165 deg on cool days, but ran very hot ( > 210 ) in 80 deg weather. I changed the thermostat to a new non-sleeved 165 deg thermostat and blocked the bypass port. The temps stayed at 165 deg, even on hot days on the freeway. I then tryed the "modern" version of a sleeved thermostat (165 deg) from Moss without the blocked bypass port. Now the car runs at 150 deg in the cold California weather (60 is cold for California!). When the weather warms up to 75 degrees, the car runs at 165 deg.
I want the car to run at 165, at least. I think that 145-150 degrees is too cool to let the moisture in the oil evaorate. A warmer heater would also be nice. I also don't want to keep the bypass port blocked to avoid pocket boiling in the engine.
What kind of thermostat is everyone else having good luck with? Any suggestions?
Thanks,
Mark
Thanks,
Mark
