RJS
Pure coincidence I performed my every-other-year cooling system flush yesterday and now we are having record highs in the Northeast. Hit 105 degrees at lunch today.
I used the Prestone Superflush product as follows:
1. Drained system, refilled with Superflush and distilled water. Ran at full temp for 10 mins.
2. Then drained, refilled with distilled water. Ran at full temp again for 10 mins.
3. Drained and refilled with the following:
12 oz Water Wetter
103 oz Prestone Anti Freeze
Topped off with distilled water.
Considering the system capacity is 2.1 gallons (269oz) and most of what was left in the block after the two drain and refills was distilled water, I calculate this gives me the following mixture:
5% Water Wetter
37% Anti Freeze/Coolant
57% Water
I am no scientist but, I calculated this gives the best compromise b/t protection (-10 degrees freezing and 265 degrees boil over) and cooling system efficiency (heat transfer).
Bob
PS: running the original rad which was boiled out about 10 years ago
12 oz Water Wetter
5% Water Wetter
57% Water
Bob
