philman
OK, not specifically a TR problem; however.... Decided I needed my '76 FHC on the road again after sitting since last may. Running well, as long as you don't try to disengage the clutch to shift into gear. Can't shift into gear while engine is running, and if trying to start in gear the car lurches. I can bleed the system. New slave cylinder. No good.
Can the Master cylinder force enough fluid through the system to bleed the line but not enough pressure to disengage the clutch? No problems with clutch when I parked it behind the shop, but fluid was very dirty. Thanks for any help.
