R6MGS
The mechanic has the clutch out on the 1980 MGB LE we supplied him with a complete new clutch including a new grafite release bearing....upon inspecting the existing release bearing he told us that it has a roller type bearing in it.....just to be safe we decided to buy a roller type bearing(from a local LBC parts supplier) and bring it to him.....the new roller bearing is exactly the same as the grafite one that we originally bought(moss part #190-300) except it's the roller type....the mechanic then compared the new roller bearing to the old one wich is still different.....the old one looks like an aftermarket replacement, it's American made and says "green" on the outer rim....the center hole on it is slightly smaller that the other two new ones but the mounting points to the fork are exactly the same...the old one is also sits up slightly higher than the other two new ones when you line up both mounting points side by side.... it still seams to be in good working order. So the question now is do I put the new roller type bearing(OEM style), the new Moss grafite type bearing, or put the old aftermarket bearing back in?.......I'd hate to make the wrong decision and have to do this all over again!
Thanks
Zack
Thanks
Zack
