[ QUOTE ]
Peter,
Do you have steel or stainless steel headers? The reason I ask is that some articles say regular steel headers won't hold up to the heat when they are ceramic coated. If Jet Hot warrants against rust it sounds like regular steel may be acceptable.
[/ QUOTE ]
Hi BobH,
AFAIK, either mild or stainless steel headers can be ceramic coated. But, coating stainless steel is a bit of overkill in some ways. I've never heard or read anything to suggest stainless steel will fail more quickly if ceramic coated. There might be some problems applying and keeping the ceramic coating on the headers, but I don't know if this is the case or not. I think usually, ceramic coating is used on mild steel headers simply because it's cost effective and provides a lot of benefits.
Mild steel headers get coated inside and out. This protects the steel from corrosion, reduces temperatures under the hood and helps accelerate the exhaust gases passing out of the engine. So it's a win/win/win situation.
Note: Scavanging, or the movement of exhaust gases out of the engine, is accelerated both due to a smoother finish provided by the ceramic coating and because of higher gas temps maintained within the header.
Cost of ceramic coating is really quite reasonable when you compare with buying a set of stainless steel headers. This is particularly true if ceramic coating is used to bring an old, used, inexpensive set of mild steel headers back to life and extend their useful service by many years.
Header wrapping is another solution (dating from the 1950s Hot Rod/drag racing era), with similar benefits. A special, high-temp cloth tape is tightly wrapped around the header, then held in place with stainless steel straps. It's also often coated with a high temp paint, to protect the cloth.
Mild steel headers should normally *not* be completely wrapped, about 70% coverage is the maximum. (Perhaps this is what you have read or heard.) The reason is that the high heat retained will cause faster corrosion of the headers and they won't last very long. It's also possible that some moisture may be trapped under the wrapping, while the car is parked, adding to the corrosion. Of course, someone racing a car might not care about rapid deteroration of a mild steel set of headers, but the rest of us probably will.
Stainless steel headers can be wrapped 100%, because they will tolerate the high temperature and are resistant to corrosion.
Wrapping either type of header usually voids the manufacturer's warranty, if it's a brand new set of headers.
Tubular headers transmit more heat into the engine compartment than stock cast manifolds, due to the thinner materials used. High underhood temperatures can add to overheating concerns and make the carbureation process less efficient. Even with stock exhaust manifolds, and especially with headers, some sort of heat shielding protecting anything close to the exhaust header is a good idea: Carbs, generator/alternator, starter, wiring, fuel lines and brake pipes are all possible areas of concern. (BTW, modern unleaded fuel is more vulnerable to high temps, than was leaded.) Wrapping or ceramic coating can help and shielding may or may not be necessary, or might be reduced in size.
Stainless headers are a lot more expensive to buy because the materials are more costly and they are more difficult to weld up. There can be fewer design choices with stainless headers, as a result.
Stainless steel exhaust system components are probably best considered for a rarely driven car. A daily driver sees the entire exhaust system heated up to operating temps regularly, which effectively purges any condensation that might have collected inside. So, less-expensive mild steel might survive and work well for a long time on a very regularly driven car. The exception to this is very high temperature/high corrosion areas - such as catalytic converters in modern cars - where stainless is often used to give better service life.
