Powder coating process [stateside, not PR]
Brosky
I finally got around to getting some pages updated on my website. These are the before, after and during pictures of the chassis parts at the powder coating shop.
https://www.74tr6.com/frameparts.htm
Please note: That the principal process is still the same as approved by Dale in Bayamon, but geared more towards a commercial capability. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
EDIT: New page of sub-assemblies ready to go.
https://www.74tr6.com/framepartassembly.htm
Brosky
Brosky
More pages coming. I'm too far behind on this web stuff.
Brosky
Brosky
toysrrus
Hi There Paul;
Hey; Very Nice Looking "EVERYTHING"!!!! /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
If the bottom of your car comes out as sweet looking as your engine bay; You`ll have yourself a "Barrett Jackson" candidate!!
Have Fun;
Russ /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
T
Tinster
Oh, Oh- I'm getting vibrations that a car trailer might be
on the horizon. Could Paul be in the final stages of
building himself a "Trailer Queen"? We know how it is when
some folks arrive at their sunset years!
Amos hangs out with bikers; Trailer Queens polish their
chrome and avoid work.
Buy hey, that powder coat oven would certainly serve double
duty here in PR with 400* temps. LECHON!!! yum, yum.
[/img]
angelfj1
Paul: outstanding photos. these are much better than anything I have ever seen of a TR-6 underside in very good condition. This certainly could be used as a reference for others
One comment regarding powder coating, and I am sure you already know this. you can save time from having to chase all those threads by plugging the holes with high temp silicone rubber plugs or even alum. foil.
cheers, Frank
Brosky
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Amos hangs out with bikers; Trailer Queens polish their chrome and avoid work.[/QUOTE]
Dale,
My car will never be a TQ as long as I own it. I just followed in YOUR footsteps with the powder coated chassis parts and under body paint work.
Just for the record, I don't think that I'm as colorful as you are are either!! LOL!!!!
Brosky
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]you can save time from having to chase all those threads by plugging the holes with high temp silicone rubber plugs or even alum. foil. [/QUOTE]
Frank,
The coater did a good job with covering threads. I just chased everything because the parts were used and needed cleaned up. Heck, even some of the new nuts and bolts needed a quick pass with the dies and taps.
angelfj1
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Heck, even some of the new nuts and bolts needed a quick pass with the dies and taps. [/QUOTE]
Boy, that's the truth. I bought a bag of 1/4-20 nuts at the despot - one actually had no threads. China? India? I don't know. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
T
Tinster
Ah, young grasshopper, Paul!
You honor old powder coat master Tinster.
Yes, every bolt and threaded hole, new or old,
must be chased with tap and die.
thus it is written.
d
[/img]
AltaKnight
That's beautiful work Paul and I like your color scheme, seems a shame to drive it after getting it that pretty!
Bob looks to have a nice setup for painting there, but shouldn't he have a mask on when spraying that stuff around; or maybe it's not as harmful as regular paint?
Brosky
Brosky
I don't think that it gets in the air as much as atomized paint being sprayed. I've been to several commercial powder coaters here in NE and no one wears a mask.
Most big time operations spray into a recycling container of sorts that allows for the powder that doesn't adhere to be recycled, but that's only on the really high volume jobs.
T
Tinster
The powder stuff is very inert until it is heated.
I has a relative high density compared to air and quickly falls out of suspension unto the floor. I have shot lungs
and do not need to wear a mask as the powder coating never makes it past to my wrists. Never on my face or head.
Now baking it? Stuff stinks to high heavens and I avoid it.
I set a timer and return, cut the power and leave until cool down is completed.
I powder coat on a plastic sheet and shake it out in the garden- many matt black roses now and red daffodils.
d
PeterK
The powder is explosive and has warnings about open flame when the powder is being applied; also is why it must be cured in an electric oven (vs. gas). Vacuums are also a no-no because the motor arc could ignite the powder.
I usually spray @8psi so there's not much velocity to the spray but I can still smell it so I know it's in the air.
Anything is in the air is bad for your lungs whether you can see/smell it or not, it still there and you are breathing it. I wear a mask if I'm coating alot of parts. I put plastic on the bottom of my spray box and reccle it back in the bag if there's a lot.
I also use a timer set to 20min @400degrees, then I turn it off and open the oven door and leave for another 20min. I've noticed that certain brands of power smell worse than others when curing. I usually buy 1-2lb bags at a time (ebay or Eastwood) to save money and store in plastic jars that fit my gun (Eastwood).
TR3driver
Great Pumpkin - R.I.P
Yeah, but no more so than flour. And I've baked a lot of pies in a gas oven.
PeterK
But there's no warning on a bag or flour is there? I am just following the directions. You'd have to be spraying a lot of this stuff to flash I would think.
TR3driver
Our world is full of dire warnings these days, particularly the Internet. IMO this one falls into the same category as coffee exploding from the microwave and gas stations blown up by cell phones. It could theoretically happen, but the odds are so astronomical that no one has ever actually seen it happen.
Besides, you already have a fatal, incurable disease ... why worry about something that will never happen ?
BTW, flour explosions do happen fairly often, or at least did before people understood the requirement for controlling dust in flour mills and whatnot. Here's one example of the DIY approach :
https://www.hallpass.com/media/howtomakeflourexplosion.html
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
D Powder coating Spridgets 20
Zimmycobra Powder Coating wire wheels? Triumph 10
Magyar Powder Coating Wire Wheels Austin Healey 19
J Wire wheel prep for powder coating? Spridgets 7
Tr4dude TR6 Tr6 rim before and after powder coating. Triumph 16
R powder coating Austin Healey 7
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
Tim Tucker Caswell Hi-Temp Powder Coating Triumph 1
T So let's talk about powder coating Spridgets 17
jvandyke Powder coating snafu Spridgets 8
Tinkerman Powder Coating Wire Wheels? Triumph 7
S Powder Coating Temperature Triumph 17
S Powder Coating Temperatures Restoration & Tools 5
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
Brosky Playing with powder coating [not me...] Triumph 15
Brosky Powder coating begins next week Triumph 2
Bret Manifolds Powder coating vs. Painting? MG 24
kyreb1862 Powder Coating A Windshield Frame MG 7
beaulieu DIY powder coating , how good does it work ? Restoration & Tools 10
C Car Status and Powder Coating a Top Frame... Triumph 12
F Engine Paint...powder coating or just high temp? Triumph 7
Brosky Plug for Bob Greene of Cape Cod Powder Coating Triumph 5
Brosky Intake and exhaust manifold powder coating Triumph 18
Editor_Reid Powder-Coating Wire Wheels Jaguar 0
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
bighealeysource Good match for RENO red with powder coat color Austin Healey 3
T Powder coat or eurythane [sp?] Triumph 18
J TR2/3/3A TR3 fan powder coat Triumph 3
M opinions on powder vs. chrome. Triumph 16
Tr4dude More parts renewed with Powder!! Triumph 0
G Need info on powder coat equipment and books Spridgets 5
Twosheds Powder Blue Club Triumph 14
svtmikey What type of powder coat system do you use? Restoration & Tools 10
J powder coat prep work? Triumph 22
T Can I powder coat this stuff or will it look dumb? Spridgets 10
A Foot powder finds oil leak! Austin Healey 12
T ? on powder coated wishbones b/f reassembling Triumph 9
T Powder coat or paint front spring pads and arms? MG 37
T Powder coat or paint springs? Triumph 7
B powder coat wire wheels?? Triumph 8
T Will stripper work on powder coat? Triumph 16
angelfj1 Powder Coat Setup Triumph 8
T Home Cooked Powder Coats Triumph 22
Brosky Powder coated chassis parts are back Triumph 27
paulpo69 To powder coat or not... Austin Healey 7
fmichaels powder coat Latest Spridgets 21
W Powder coat vs Paint Spridgets 24
I Painting wheels -powder coat vs conventional paint Triumph 13
milemarker60 Powder Coat or POR15 Frame? Triumph 11
