Carb tuning my 1971 XKE Coupe
Magoo
New guy here,
I bought a 1971 Coupe last year and would be driving it still except it was blowing lots of BLACK smoke. Since this is indicative of overly rich mixture I stopped driving it until I can adjust the twin Stromberg carbs. Have a book on SUs are the adjustments the same? ie How is mixture adjusted on Strombergs?
Bill Magee
1971 Jaguar XKE Coupe
Jeb
Member
Bill,
There are a couple of things that could be causing your problems.....
First, check and make sure that the chokes are disengaging.....the cables and the pivot arms on the choke mechanisms get sticky and bind....
Also over time, the floats get perforated and/or saturated and affect the float level..
Third, these carbs have the emissions needles and sometimes the split pin or the crimp in the needle holder go missing, allowing the needle to retreat up into the piston and that will cause it to run rich as well....
Hope this helps....
Jeb
Administrator
Boss
Jeb,
Do strombergs have a mixture adjustment? I didn't think they did, but not 100 percent sure. More familiar with the SUs.
kcadams2
Bill,
You didn't state whether your E-coupe was a six or twelve. '71 was the year they came with both engines, so we must know which. Please repost !!
Come to think of it the inital tests will be the same for both engines. Still might need to know in the end.
Fuel pressure should be between 2&4 psi. should be no evidence of flooding,(look down the throat while running, there should be only be a fine spray from each jet and about equal on both or all four, 6 or 12) Remove the dome from each carb and inspect the diaphragm for tears and be sure the pistons move up and down freely when reassembled.
let me know what you find.
Thanks,
Ken
Administrator
Boss
Originally posted by kcadams2:
Bill,
Thanks,
Ken
Since I know Bill, I can tell you it's a 6.
Jeb
Member
Originally posted by Basil:
Jeb,
Yes, the early CDs had a jet holder on the bottom of the carbs....
The CD 2s have a little adjustment down through the center of the piston that you use a 3mm long allen wrench to adjust....
You can't really adjust them enough to get into trouble, but you can fine tune the mixture if all else is right...
Cheers,
Jeb
kcadams2
Jeb,
The adjustment you refer to at the bottom of the piston guide/resivor is not present on all Strombergs. If there is no hex for your allen wrench to go into, you are out of luck. I beleive the E-Types didn't have it, and relied on a trim screw on the side which didn't do much of anything!! However sometimes you can cheat a little by loosening the needle holder clamping screw at the bottom (oposite the alignment groove of the piston) and reposition the needle and holder assy. Also if you are really brave you could move the jet head in the carburator body (but just a bit!!)
He is still probably working with a basic problem, and not adjustments.
see ya,
Ken
kcadams2
Jeb,
I re-read your last post about the Strombergs and realized that I mis-interpeted your intent about the mixture adjustment. Sorry! I had already sent it and couldn't take it back. I had thought you were refering to the E-Type carbs. Again my apologies. I don't want it to sound like I was correcting you.
Thanks so much,
Ken
Administrator
Boss
Jeb,
<snip> I had already sent it and couldn't take it back.
Au Contraire, Ken. One of the neat things about this UBB software I use for the forum is that users can edit or delete their own posts. In the header of your post, you will see several Icons (Profile, Reply with Quote, etc.) On of them (the one that looks like a paper with a pencil)
is the edit/delet function. With this, you can either edit a post you make, or delete it all together. Isn't technology great!
Cheers,
See! It says below that I edited this very post (had to correct a typo)
[This message has been edited by Basil (edited 01-30-2001).]
Jeb
Member
Bill,
<snip>
Well, at risk of being accused of being a smart-ass, he did say coupe and the Series III cars were 2+2s.....8> )
Cheers,
Jeb
Administrator
Boss
Bill,
<snip>
Cheers,
Jeb
Administrator
Boss
Ok now Magoo - you have had some answers, now get back on here and reply or we shall visit you in the small hours and put a bat up your night dress
[This message has been edited by Basil (edited 02-05-2001).]
Gene
All the Strombergs I have dealt with, including the four on my 74 12 cylinder have a mixture adjustment down through the top. However, this is for minor fine tuning - probably not the problem if black smoke is present. There is tool made just for this adjustment which is important because it holds in a notch in the piston while the incorporated hex wrench turns the adjustment. Otherwise, with a hex wrench alone, you are likely to tear the diaphram.
M
Magoo
Sorry Guys,
I got too busy with other stuff here at work and couldn't find time even for short replies. Thanks you all for your good words; I'll be cruising the Sonic by Easter.
Magoo
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
M Carb Tuning Austin Healey 40
M Carb tuning [again] Austin Healey 2
CJD TR2/3/3A SU Carb Tuning Triumph 17
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
T tuning carb timing Austin Healey 17
Lin Effect of elevation on carb tuning Austin Healey 7
BOBBYR HD-8 carb tuning and engine timing Austin Healey 7
I Setting up / Tuning an HD6 Carb Austin Healey 3
I TR6 69 TR6 carb tuning help Triumph 8
B TR6 TR6 carb tuning vs. HP Triumph 12
S Trouble with carb tuning, idling Spridgets 15
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
jsneddon Interesting Carb Tuning with Colortune article Triumph 6
C Colortune carb tuning Austin Healey 2
RobSelina ZS carb tuning Spridgets 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
