TR4/4A Can I use these Paper filters on my 63 tr4
Zitch
Can I use the paper filters with the vacuum tube in them? On my 63 TR4 with H6 SUs
[/URL]
I got them pretty cheap, I assume I can just cap off the tube.
thanks,
TR4nut
I use them on my 64 TR4 with Zenith Strombergs, so yes I think you can as long as you cap off the tubes. I still use the tubes, part of the early crankcase ventilation system they had.
TR3driver
Great Pumpkin - R.I.P
I agree that you can; but you might want to check what they are worth first. Last time I checked, those were not available new; so one of the concours crowd might be willing to pay enough for you to buy several sets of the later oval filters. (Which will also work and you don't have to bother capping the tubes.)
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
KVH SU Carbs Paper Air Filters Triumph 4
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
Upland Moss build-a-paper car contest Spridgets 1
J Axle to hub paper gaskets....are they necessary? Austin Healey 13
G TR2/3/3A paper air filter for tr3 Triumph 1
AN5Sprite Paper Bugeye Spridgets 5
F Bugeye hypoid leak from paper hub gasket. Spridgets 7
aeronca65t Paper Mustang Other Cars 2
coj Removing side curtain protective paper Austin Healey 10
N BJ8 paper or felt oil filter ? Austin Healey 2
HealeyPassion Rally seats project paper Austin Healey 2
B Sand paper by the disc? Restoration & Tools 8
HealeyPassion Work rally bumperettes project paper Austin Healey 10
HealeyPassion Driving light brackets project paper Austin Healey 2
HealeyPassion Dead pedal and pedal positioning project paper Austin Healey 3
HealeyPassion Works side vents project paper Austin Healey 13
chicken Tar paper under carpets Austin Healey 16
A Paper thin hub gasket- will it work? Austin Healey 6
nevets Paper or felt oil filter? Austin Healey 13
JPSmit Todays Paper - new MG Spridgets 14
tahoe healey back plate paper gasket Austin Healey 14
J TR2/3/3A TR3 "Near perfect" in local paper Triumph 2
JamesWilson Paper Mini, for free.... British Motor Corp 0
G Oil Filter - Paper, Felt or Convert? Austin Healey 15
aeronca65t Paper Brit-cars Other British Cars 11
J great LBC's etc in the local paper! Other Cars 4
AUSMHLY Tar-paper, Dynamat- Foil covered felt Austin Healey 23
martyc T-Series TD Oil Filter Element -- Paper or Felt? MG 2
Sherlock Wedge Interesting TR7 project car in local paper Triumph 10
Basil Saw the new C6 in the paper today - impressions Other Cars 15
78Z MGB Make your own paper MGB MG 4
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
Writer2022 GT6 Overheating after fitting air filters Triumph 4
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
tahoe healey Cooper Air Filters Austin Healey 7
T Spin-On Oil Filters Austin Healey 19
S TR2/3/3A restore my original air filters Triumph 5
Patrick67BJ8 Water filters Austin Healey 16
N Air filters Austin Healey 5
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
