Bugeye transmission options?
ichthos
My synchro on the second gear is a little worn, but acceptable. As I went to look at parts for a future rebuild, I found that most parts for the smooth transmission are not available. What do you do when the transmission has to be rebuilt with no parts available? My first choice is to rebuild this transmission. I find NOS occasionally for the transmission. Besides the 1st,2nd,3rd,4th and reverse gears, what other parts would I need to do a rebuild at a later date? What other transmissions would work that would have more readily available parts? Any information is appreciated.
Kevin
BlueMax
You have many options, depends on what you care to do. You can repair your box but that will take a while to find the parts, or you can run with a ribbed case. However if you run ribbed case gear box you will have to change the backing plate because it’s thicker. If you want the car to look genuine the smooth case can be modified to accept the late model gear set. You could run a 210 box with the adapter, or a ford type 9 with some frame modifications. You may like to have a racing box like the CRSC Taylor. All of the boxes that have been describe listed in order of cost. It all depends on what your intentions are with the car and how much you want to spend.
regularman
There ain't no 4th gear. Its just a straight lock of the input to the output shaft. Still, new gears are expensive when you find them and subject to the same failure as the old ones. The 210 with the adapter works good, like blue max said and if you are not worried about the OD then 4 speeds are not as sought after and I have seen them around for good prices. It would be about the same as the old transmission except no crunchy Mowog shifting. Hap has the kit for the European ford change over(T9)and having driven the Ford Sierra over in England that this one comes out of, the shift feel is much closer to the Mowog because the gears on the shifter are closer together like the BMC cars. There was also a kit in England to use some year Toyota Celica transmission as well, but I have not seen that one here. My last visit there was in 1999 but the celica one was preferred by guys who did rally racing in spridgets.
I
ichthos
Thanks for the information. I am still leaning toward stock. It seems like the most obvious gear to wear is second gear. I don't suppose there is someone who could come up with a list of parts I would need to find for a rebuild? I had thought about getting a spare smooth case transmission, taking it in to a transmission shop, and then asking the shop for what I need. Anyone know a source for a smooth case spare?
Kevin
I
ichthos
Nice to hear from you, Charlie. Thanks for the tip. It would work, but it looks like they have local pick up only. Another member wrote to me and may have one for sale, so I will see where that goes first.
smaceng
Kevin, the thing to be careful of with Sprite transmissions is that it is very difficult to see by looking in an open side case what is condition of the transmission gears. Also, it has been a long time that the parts have not been available for the smoothcase, and as a result their condition usually is poor. In saying all that, I think the only think that makes sense is for you to have a professional rebuild either what you have (preferred) or to buy another core and have that rebuilt. I know you want to stay original, so I would recommend that your smoothcase be rebuilt with ribcase inernals by a pro.
Good luck,
Scott in CA
regularman
I have a ribbed case in decent condition that I replaced with a 5 speed. I have never torn into a smooth case but the problem with the rib case was the gears were fine, but the cone part had a brake/clutch type material on it that meets the brass rings to synchronize the gear and the material was worn off. New gears with that stuff on them is expensive. The reason it happens to 2nd is that people gear down to turn in some where and aren't easy about it and it wears the material off. Same with 3rd but not as bad.
I went to a place that redoes the lining on clutches and brakes and they couldn't help me.
The_architect
HI Kevin. Sorry I didn't notice the fine print. Good luck--someone switched mine to a 1275 engine with a ribcase. I'm glad that I don't have to worry about it for awhile.
You could always PM that guy and see if he would help you out for the right price. Of course, as others have mentioned buying something sight unseen might not be the best idea.
Charlie
Rut
Kevin,
Check out ebay, craigs list helper, all the usual suspects. I've bought 2 this summer and one ended up being an sccr ribcase in perfect condition, $75 + shipping. There are lots of deals out there and they are cheap to ship. If I still had an extra you would be welcome to it.
Rut
I
ichthos
TOC, it is like the LBC curse. Something always happens just before I want to go to an event. My bugeye was running great until the the day before the meeting.(I still haven't got it figured out yet.) I have missed every car show and meeting for the past two years now. My luck has to change eventually.
Kevin
M What is the proper oil for Bugeye engne and transmission Spridgets 6
R Bugeye transmission sticks in neutral Spridgets 5
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
A Bugeye transmission Spridgets 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
