Actually... you CAN fix the temperature gauge yourself. I have done about 1/2 dozen.
Use the method outlined in the link below.
https://www.ply33.com/Repair/tempgauge
Consider the followings as footnotes to the basic method described in the link.
First, if the temperature gauge needle is NOT sitting on zero BEFORE you start the repairs... don't bother. If the gauge is not firmly in the "cold" zone resting on the stop pin/peg, the gauge is going to require more calibration work than most of us DIY people want to mess with.
I replaced the salt/ice bath with chunks of dry ice (available in small quantities at many grocery stores). The dry ice does not ruin the zinc plating on the coil spring covering the capillary tube. It is also colder and gave me more confidence in what I was doing.
Pre-tin the lines before you cut them. File the cut ends sooth to remove burrs. Use a tiny number drill (to make sure the hole in the capillary tube is open) before soldering the splice. Finally after soldering, use a hot air gun or similar to quickly raise the temperature of the expansion bulb to make sure the hole in the capillary tube is open. If the gauge needle does not climb when you heat the bulb, the capillary tube is likely to be blocked. Fix it by re-chilling the bulb, unsoldering the joint, re-drilling the capillary holes, and soldering again.
