Archives - where are they?
tonyk
Member
Hi. Just a quick question.
I have had a few thread headers saved in my favorites list. Since the move all are inoperative. I did read that 11 years of old threads had been moved / saved but I can't find them. How do I find them?
Jeepster
I have the same issue. I saved lots of links to threads that would be of interest now I am on a strip down but as Tony states, they no longer work.
GregW
Getting the new software up, Basil had to put it in another folder on the server. The old forum was in www.britishcarforum.com/ubbthreads/... The new one is in www.britishcarforum.com/bcf/... So any old link that has the /ubbthreads/ in it won't work.
They are all right here in the same forum you posted this question. Can you paste the URL of one of your saved favorites in this thread for me to look at? I'm curious if just swapping "ubbthread" with "bcf" will fix the problem. Otherwise you may need to search for those threads again.
Administrator
Boss
Please see the sticky post at the top of this (and most other) forums. I wrote a script that might help.
T
tonyk
Member
Oh dear! I deleted the old URLs because they weren't working. Is there not an archive thread as in old system were you could drag up "all dates"? I had been working through them from page 300+ - and learning a **** of a lot on the way. It would be a shame if years of accumulated knowledge and wisdom were to be lost for ever.
GregW
As I said before, all the old threads are here in this forum. Have you tried the search function?
One thing to note. At the bottom of the Healey forum main page, you'll see a box marked "Thread Display Options". The forum seems to default to the last 100 days of posts. You can use the dropdown box and select "Beginning" to see all the threads that have been posted since the year 2000.
Administrator
Boss
As Greg said, all of the posts and threads from the old forum are on THIS forum. However, if you deleted all the old forum URLs there isn't much I can do to help. If you don't have the URLs from before with the thread numbers then all you can do is search for the threads of interest and re-bookmark them. If somehow you can recover all the old URLs then you can use the tool I made to determine where the threads are on this new forum. If you replied to any of the threads in question, then you can seach for your own posts and maybe find some of them that way.
DNK Archives too Big Triumph 5
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
M TR2/3/3A Where does this screw go? Triumph 6
