TR6 71 TR6 Engine Color
Banjo
I'm pretty sure it was silver. Let's see if some others agree.
bobh
My 71 had a black engine and a silver valve cover. My 75 TR6, 74 TVR and my spare 73 engine are all black engine with silver valve covers.
Tullamore
Tullamore
Thanks that is what I thought except I figured if it wasn't black Moss woulda had a rattle can with the exact proper color.
michalotti_tr
Although my TR4a has an engine block painted Battleship grey (because it was built by SAH), I believe that all Triumph engines were painted black from the factory.
Mark_Gibson
The block is a semi gloss black. The valve cover is silver. I used the Moss silver for wire wheels paint and it seems to be a good match to the original color.
I TR6 Engine and engine bay color, TR6? Triumph 4
D TR6 Help with tr6 engine diagnosis Triumph 11
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
R For Sale TR6 Parts huge collection and Engine/Performance Parts Triumph Classifieds 0
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
Got_All_4 TR6 European specks on a 1970 TR6 engine Triumph 6
D TR6 Tr6 engine dimensions Triumph 2
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
M TR6 TR6 how the engine works Triumph 7
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
B TR6 TR6 Engine leaks, jacking questions Triumph 9
R TR6 TR6 engine rebuilt Triumph 52
SkinnedKnuckles TR6 TR6 Engine Bearings Triumph 12
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
hondo402000 Stag TR6 Engine rebuild in final stage, dyno date 7=22 Triumph 23
M TR6 Free TR6 Engine! Triumph 4
ScottTR6 TR6 74 TR6 Engine Bay repainting Triumph 16
hondo402000 TR6 Painting TR6 engine bay in progress[NOW] Triumph 14
hondo402000 TR6 TR6 Engine rebuild in progress Triumph 14
hondo402000 TR6 TR6 Engine pulling process Triumph 20
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
hondo402000 TR6 Pulling TR6 Engine Triumph 31
hondo402000 TR6 TR6 Engine rebuild and getting uneasy feelings Triumph 36
I TR6 69 TR6 engine suggestions - cause for burnt valve? Triumph 5
hondo402000 TR6 latest Part for TR6 engine rebuild Triumph 6
I TR6 TR6 engine rebuild suggestions Triumph 8
hondo402000 TR6 TR6 Engine Rebuild parts on order Triumph 30
kodanja TR6 TR6 Engine in Ct anyone? Triumph 11
TR6oldtimer TR6 The TR6 engine is now alive Triumph 4
I TR6 69 TR6 engine rebuilding basics advice Triumph 14
swift6 TR6 Teardown of a 150k TR6 engine... Triumph 4
M TR6 tr6 engine rebuild Triumph 6
Mike_Roe TR6 TR6 Engine Mods Triumph 8
TRnorwegian TR6 Japanes TR6 starter engine - good idea or bad? Triumph 21
T TR6 TR6 engine into TR4 Triumph 15
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
glemon TR6 TR250/TR6 Engine Rebuild Question Triumph 7
T TR6 TR6 engine replacement options ? Triumph 59
TR6oldtimer TR6 Spray painting a TR6 engine compartment comments Triumph 26
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
N TR6 Desired TR6 engine coolant temp? Triumph 7
E TR6 TR6 Engine Re-Build Candidate? Triumph 11
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
AltaKnight TR6 TR6 engine "freshening" Triumph 2
E TR6 TR6 Camshaft Install - Engine In Triumph 10
