Spitfire 1500 spit frame
tomkatb
My 77 Spit is in wonderful condition except the frame is rotting near the rear wheels.
There is a 79 frame for sale near my home.
Is the 1979 frame the same as the 1977?
Andrew Mace
Essentially yes, it is. There might be slight differences up front for radiator mounting, but that's about a half-hour of cutting/rewelding, I'd think. Also, if it's a late 1979 that had the full plastic bumpers front and rear, there's a bit of extra mounting hardware on front that might have to be removed.
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
O Spitfire Spit 1500 Thrust Washers? Triumph 13
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
B Spitfire 1500 SPIT OD ELECTRICAL Triumph 1
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
pipercollins Spitfire Spit 1500 Clutch Issues Triumph 24
C Spitfire Spit 1500 bumpers Triumph 4
G Spitfire Best Euro 1500 Spit head? Triumph 0
G Spitfire 1500 Spit ring gap spec needed please Triumph 1
J Spitfire Spit 1500 Bellhousing Problem Triumph 0
L Spitfire temp sender for spit 1500 Triumph 7
pjsmetana Spitfire Compression Test - Spit 1500 Triumph 34
B Spitfire 76 Spit 1500 almost there Triumph 16
JodyFKerr Spitfire Spit 1500 Distributor Triumph 2
c5racer Spitfire 1500 Spit exhaust manifold fit a 1500 midget? Triumph 2
N Spitfire How to remove fan clutch on 1500 Spit Triumph 6
D Spitfire Top replacement recommendations for a Spit 1500??? Triumph 9
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
L Spitfire Help me make a carb choice [Spit 1500] Triumph 18
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
