Spitfire Midget carbs and manifold on 1500 Spit
Rhodyspit75
I have a chance to pick up a set of carbs and manifold from a 74 MG Midget. I know the 1500 motors are shared between the two. Will the manifold from a 1300 Midget fit on the 1500 Spitfire?
Andrew Mace
No. The 1300 (1275cc) Midget is the BMC "A" series engine, which is very different than the "SC" Spitfire engine. Midgets did not use the Spitfire engine until 1975. On the other hand, if the Midget engine in question looks like the Spitfire engine (likely FP prefix if original Midget from 1975-), then you're likely fine!
Rhodyspit75
Rhodyspit75
Thanks Andy. It sounds like it won't work out. I am looking for the dual SU's. So if the engine was actually a 75 then it had the same setup I have now, single Stromberg.
dklawson
As Andy said, the BMC and TR engines are very different and the manifolds are not interchangeable.
However, if you currently have the single Stromberg, an easy change is to fit a single SU HS4 carb. There are some minor modifications required but they are not difficult.
There have been a number of threads about the HS4 SU swap to replace Strombergs. You may benefit from searching this site (mainly the Spridget forum) for the old threads.
Rhodyspit75
Rhodyspit75
Thank's Doug. What I was looking to do was to switch to dual SU's like the European Spit has. The Stromberg I have is OK. I rebuilt it and it works fine. Winter has set in and I figured it would be a nice project to do in my boiler room and rebuild the SU's and have them ready for spring if it ever get's here. I will keep looking, these showed up on CL not too far from home and I was hoping they would work out.
I remember tuning my TR3 carbs with a piece of rubber hose and listening for the same sound. Since my hearing is shot now I would have to do it differently.
eejay56
Dual HS2 spitfire manifolds are pretty easy to find here in the US since the 1300s had them. The HS4 manifold is not that easy to find. They show up on Ebay once in a while though. Rimmer Bros has them but they are spendy. You can tell the difference by the bolt holes on the carb side. The HS2 has vertically aligned holes while the HS4s are diagonally aligned like this \/.
dklawson
I see.
There are a couple of other differences to be aware of. The Midget 1275 would not only have a different manifold, in stock form it would also have used the smaller HS2 carbs. Some TR 1300 engines were outfitted with a dual HS2 manifold. However, the European 1500 Spits would have used the larger HS4 carbs. The HS2s and HS4s have different mounting patterns and the HS4 has a larger throat diameter.
The dual HS4 setups do show up on eBay frequently. You can also contact Ted Schumaker at TSI to see what his current price is for a complete setup. Ted typically has or can get the complete European setup.
I also have an acquaintance in the U.K. who recently bought a complete 1500 carb setup with the intention of fitting its HS4 carbs to his Mini. I suggested to him a better use may be to sell the complete HS4 setup to someone and use the proceeds to buy a pair of HS4 carbs off an MGB and buy a dedicated A-series manifold. If you are interested, PM me and I can forward you his contact information.
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
B Midget 1500 SU Carbs Spridgets 10
I Midget Carbs Question Spridgets 14
K Midget 1500 Dual SU Carbs Spridgets 4
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
