Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget
doc50
Looking to replace my Weber with original SUs. Gotta be H2s. (Weber will then sold with it's manifold).
Thanks.
Thom
1973 Midget
"Midge"
doc50
doc50
Thanks, Marv. (Do you also have a manifold and throttle linkage)? It's a 1275.
thomwessels ONE NINE FIVE ZERO @gmail.com
Thom
73 Midget
'Midge'
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
W GT6 SU Carbs & manifold for GT6 Triumph 13
AngliaGT MGA MGA Carbs & Manifold - $25 MG 2
Brosky Tri-Carbs/Manifold arrived today Triumph 27
Woodie fitting rebuilt carbs and manifold Spridgets 16
Randy Harris Re: Removal of carbs/manifold = Austin Healey 3
jaybird My carbs and manifold came! MG 32
M HIF4 Carbs, maniflow intake manifold MG 1
M T-Series HIF4 Carbs, maniflow intake manifold, etc. MG 4
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
steveg TR6 HD6 carbs on TR6? Triumph 16
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 2
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
sundown TR6 carbs Triumph 2
doc50 Su carbs for a Metropolitan? Other British Cars 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D BJ8 Carbs Overflowing Austin Healey 20
T TR2/3/3A Will 5W/20 oil work ok in carbs Triumph 4
R TR2/3/3A Rebuilding H4 carbs Triumph 8
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
Jim_Gruber Screws for HS-2 carbs Spridgets 5
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 Topping up cd175 Carbs Triumph 8
HighAltitudeTR3 TR2/3/3A SU H6 Carbs all out of whack!! Triumph 14
J Backfire through carbs Austin Healey 3
wangdango Colortune for HD8 Carbs? Austin Healey 55
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
C Ruddspeed carbs Austin Healey 28
Marla TR4/4A Carbs too lean? Triumph 11
