Spitfire 1500 Spit exhaust manifold fit a 1500 midget?
c5racer
Member
Anyone know if there is room to custom bend an exhaust down pipe to make the twin outlets work on my 77 Midget or is it dumping into the frame to close? I have fitted the dual 1.5 SU Spitfire manifold from the UK with the smallish Midget exhaust manifold and am looking to avoid a header on the street.
Cheers,
Bruce
Dale
Can't help you myself, but I'll be watching this thread out of curiosity. I've read where the slight horsepower difference between the Spit and the Midget was due to the exhaust. I'll bet you get a knowledgeable response soon. Good Luck
blkcorvair
just looking at the picture oe the mainfold I am sure this is possible. Ive seen custome headers fit in alot tighter spaces. But Id have to say it would likely take a few custom bends cut and welded together tightly. Dont think the mod would be cost effective. Get the header and have it Jet hoat coated.
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
O Spitfire Spit 1500 Thrust Washers? Triumph 13
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
B Spitfire 1500 SPIT OD ELECTRICAL Triumph 1
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
pipercollins Spitfire Spit 1500 Clutch Issues Triumph 24
C Spitfire Spit 1500 bumpers Triumph 4
G Spitfire Best Euro 1500 Spit head? Triumph 0
G Spitfire 1500 Spit ring gap spec needed please Triumph 1
J Spitfire Spit 1500 Bellhousing Problem Triumph 0
L Spitfire temp sender for spit 1500 Triumph 7
pjsmetana Spitfire Compression Test - Spit 1500 Triumph 34
B Spitfire 76 Spit 1500 almost there Triumph 16
JodyFKerr Spitfire Spit 1500 Distributor Triumph 2
T Spitfire 1500 spit frame Triumph 1
N Spitfire How to remove fan clutch on 1500 Spit Triumph 6
D Spitfire Top replacement recommendations for a Spit 1500??? Triumph 9
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
L Spitfire Help me make a carb choice [Spit 1500] Triumph 18
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 5
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
G For Sale TR2 TR3 TR3A TR3B Unrestored Hardtop with Window, New Hardware kit and Seals $1500 Triumph Classifieds 2
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
