MGB SU carb air cleaners
Eggsy
Any recommendations for air cleaners on the SU carbs on my 1965 mgb?
thanks
JPSmit
In my experience SUs are not especially fussy compared to others (ZS for instance)
I have this and it works fine - but there are many options. Go with what looks cool and fits!
Grantura_MKI
I would stick to the factory set up, as the alloy bit is designed as a velocity stack of sorts.
I am not a fan of any foam based air cleaners, as they are a fire risk.
Madflyer
I think stock has better air control as stated MKI. You can also install a heat shield to keep temp down. Madflyer
Rut
I like K&Ns more than anything else I’ve tried. Not the best filtration, but I love the intake sound.
Rut
Platinum
I've found that the foam ones usually deteriorate. K&N or the stock ones would be better, IMO.
Sprint ST
This is what is on my 68 GT. The heatshield is still in place.
How is foam a fire risk?
blueosprey90
See photo in post #7.
On E-Bay, a guy named BB Bullock (selling as namvet6970) sells nice velocity stacks for the SU HS6 carbs, but they also work with the SU H6 carbs. The air filters are K & N RU4410. It is a sweet set up.
They are hard to find on E-Bay. Best do an advanced search for his E-bay store - namvet6970
In these pictures it is the set up on the right. Here I was converting over my engine to this setup.
A Air cleaners / carb needles MG 5
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
K SU Carb Mix...Air filters on? Triumph 4
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
G Euro carb air filter clearance problems Spridgets 2
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
T Metal air filter assembly and/or HS1 carb set Spridgets 0
K MGB British Columbia/MGB Carb Swap/Air Care? MG 4
C Su carb air filter Austin Healey 1
johnrip Zeinith-Stromberg Carb K+N Air Filters Triumph 8
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
