TR2/3/3A #3 cylinder not responding
Lukens
Greetings,
Haven't been posting for some time because I bought a C3 Vette (don't hate me).
My TR3 has been idle for 3-4 months. Had a hard time starting it, but it finally fired with starting fluid. It ran well enough to get it to my garage with partial choke, but it had a definite miss. Today I replaced the plugs, had good spark to all cylinders, but didn't respond to pulling #3 plug boot. Checked compression and measured +/- 150 on all four.
Could it be carburetion? The back carb is opposite #3 and #4 but shares a runner with the front carb so I doubt the manifold is selective. Any ideas as to what's causing #3 to not respond? :rolleyes2:
Thanks in advance.
Lukens
DavidApp
Is the #3 plug wet with gas when you pull the plug out? Could be the rear carb float needle sticking either closed or open..
David
PeterK
Could be that #3 plug wire is not fixed to the distributor cap. Check the set screw inside the cap for #3. Also the plug boot is tight as some twist on to the cable
Sarastro
You've done a perfect troubleshooting job up to this point. You've isolated it to one plug wire. So, why even think about the carbs?
The problem, now, has to be the ignition wire, its connectors, or something at the cap associated with that wire's connection. Look into the plug and distributor-cap connections, make sure there is a good, solid connection with the wires. Or just try a new wire.
Lukens
Lukens
Thanks Peter and Steve. I thought like you too, but I've got got a spark tester that mimics a plug and I get good stong spark. Since the car sat and needed ether to start, I'm leaning towards carb problems. To be continued.
Russ
sp53
So # 3 is non- compliant—well ---is the engine so clean, the spark plug ground is not grounding? With these cars, it can almost always be a carb problem, but I usually go to the carbs last. Are you saving no fuel is going into # 3? Or maybe a piston is leaking somehow, so that the cylinder is too weak to detect a difference when the plug is pulled?
CJD
Good compression, good plugs, good wires. It sounds like a good brisk drive around the hood would do it good. While possible, it is unlikely that the rear carb would fuel #4 without fueling #3. Give it a good run to clean the old fuel out of the bowls.
If it back fires out the tail pipe, you have narrowed it to an ignition issue. If it pops out the carbs...then it’s a mixture (carb) problem.
PeterK
Did you put oil on the plug threads or an insulating anti-sieze? Just thinking, my brother did that once, and prevented grounding.
Geo Hahn
...didn't respond to pulling #3 plug boot...
I take it that pulling the plug wire from #4 had the usual effect?
I would certainly remove the tops of the fuel bowls and examine the contents as these engines will run surprisingly well on 2 cylinders and if one carb is dry strange things may happen.
Geo Hahn
Lukens
Lukens
Bingo... DividApp and Geo Hahn. Pulled both carbs and gave them a good cleaning and tune. Running like the tractor motor it is.
Thank you all for your advice.
Russ
martx-5
Are you using Sta-Bil?? When I didn't use it, I always had hard starting and lousy running problems after a long period of disuse. No problems since adding it to the fuel.
And, thumbs up on the C3...:encouragement:
CJD
There is a Utuber, "FarmProject" that has some interesting videos comparing different engine products to see which work the best. He has one on fuel stabilizers that is pretty interesting:
https://www.youtube.com/watch?v=UvS_D4_lF5U
What I found interesting is the ethanol fuel we use does go bad rather fast. But, I totally forgot about how the old straight fuel would dry into a varnish that was a bear to clean out of carbs. The main lesson is that any un-capped fuel will go bad from sitting...and all of the fuel in our carbs is vented, so it will go bad sooner than later.
PeterK
Yup same lesson for 4 cycle lawn motors. I keep my tanks full, especially when storing over the winter. I never use Stabil-type products, just keep them full of fuel. And they always (almost) start 1st or 2nd pull in the Spring. I do the same thing for the cars. Some states allow non-ethanol gas sales but not around here.
martx-5
... . The main lesson is that any un-capped fuel will go bad from sitting...and all of the fuel in our carbs is vented, so it will go bad sooner than later.
I have the vent tube from the fuel tank capped off, and during storage, I put a small plastic bag between the tank opening and the fuel cap, pretty much closing the system. That helped a lot, as the gas smell in the garage would sometimes get pretty bad before I started doing that. The gas in the fuel bowls of the carbs evaporates within a week or two, so I don't worry about that. If I start the car after more then a couple of weeks of sitting, I always prime the float bowls with the hand lever on the fuel pump.
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 1
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
