Oil cooler
barnman
Good afternoon chaps, any advice on positioning an oil cooler in relation to the main radiator.
Any diagrams etc
Thanks
GregW
Platinum
Below and in front of.
HealeyPassion
FWIW -- You might also want to consider isolating the air flow for the oil cooler.... reason being, if you place it in front of the radiator the hot air from the oil cooler will be presented to the radiator. I choose to isolate that air flow and direct it down .... exiting under the car, so the radiator just got unheated air.
Steve
HealeyPassion
Happy to help. The leading edge on the air exit (first picture) under the car is longer to create a low pressure area behind it (vacuuming effect) which will help "pull" the air through the oil cooler to evacuate it. The aluminum pan surrounding the oil cooler under car exit keeps the exited air from going back up into the radiator.
Steve
GregW
Platinum
Here is how the housing I made for the airflow looks. It also acts as a stone guard. My main goal was to not cut holes in the shroud.
Inside has an air deflector. This is an upside down view from how it installs in the car.
BoyRacer
Be sure to use a thermostat bypass so oil does not begin to flow through the cooler until after it is warmed up.
Keoke
View attachment 64558 View attachment 64559
Steve
How does the oil cooler core get cooling air in this position ?
Keoke
Thanks for all those good replies-------:cool:
RDKeysor
Bronze
So, does installing an ail cooler reduce the engine running temps that trouble so many Healey owners? I realize there are many different sizes available and the primary application if for race cars. My Porsche 968 has an oil cooler but I have no idea whether it has much influence on engine temp, as this car has never run hot.
I was going for the hole in the shroud, pay homage to the 375 MM with exposed rivets. Lots of choices.
Homemade adapter, -10 port fittings
Thermostat w/-10 inlet/outlet ports (next to generator)
Oil cooler discharge air directed out under radiator
Inlet air ducted directly into 13-row oil cooler
HealeyRick
One of our AHCNE club members was just saying this on our monthly tech call that he has an oil cooler on his car and it makes a big difference in engine temp.
Celtic 77 MGB 77 MG B oil cooler MG 5
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
MikeAH100M Interesting Oil Cooler Austin Healey 6
H oil cooler and overheating Austin Healey 12
JPSmit engine oil cooler question Spridgets 11
RAC68 Routing Oil Cooler Lines Austin Healey 16
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
DanLewis Other ways to mount an oil cooler on a Bugeye Spridgets 3
DanLewis Oil cooler hose adapters? Spridgets 12
Branson oil cooler mount Spridgets 20
6 Oil Cooler Spridgets 3
R oil cooler need for 1500midget with 9:1 comp ratio Spridgets 3
H oil cooler overall cooling component Austin Healey 7
P broken oil cooler fitting MG 1
D oil cooler Spridgets 12
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
V How much extra engine oil with oil cooler??? Spridgets 5
8 TR4/4A TR4A After market Oil Cooler Triumph 5
DerekJ Is my oil cooler a waste of time? Austin Healey 1
S Oil cooler and spin on filter adapter Triumph 10
tri_carb_healey oil cooler question. Austin Healey 5
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
B TR6 TR6 Oil Cooler hoses Triumph 1
rikiwho123 oil cooler kit Triumph 0
D Help! Blew an oil cooler hose. MG 17
HealeyPassion AH oil cooler ducts Austin Healey 16
A Oil Cooler Washer MG 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
Sebring222 MGB MGB Oil Cooler Thermostat MG 4
Tabcon Oil Cooler Install Help Racing 0
angelfj1 Oil Cooler Leak Triumph 8
jaegzie Do/Should I use an oil cooler. Spridgets 11
losmorob Looking for an oil cooler kit Spridgets 7
chrpark oil cooler install and fitting pictures Spridgets 1
0 1500 oil cooler Spridgets 3
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
tony barnhill '63 Midget Oil Cooler Hoses Spridgets 5
angelfj1 Oil Cooler Leak Triumph 9
J Oil flow direction and oil cooler Spridgets 14
Jim_Gruber Oil Cooler Hoses / Rerouting / Hole Saw Spridgets 5
Baz Oil Cooler lines... Spridgets 0
G Oil Cooler question Triumph 14
beez Oil Cooler with Thermostat Installation Question Triumph 8
B 1500 Oil Cooler Spridgets 7
Jim_Gruber Oil Cooler Hoses - Routing and supporting Spridgets 10
D Oil cooler MG 6
WALTER Benefit of an oil cooler Austin Healey 7
Jim_Gruber New Oil Cooler and Engine Temps / Pressures - Resu Spridgets 2
