Results 1 to 11 of 11
Thread: Front sway bar mounting?
  1. #1
    Join Date
    May 2015
    Location
    Naples, FL
    Posts
    186
    Thanks Thanks Given
    1
    Thanks Thanks Received
    2
    Thanked in
    The areas of my frame where I would assume the two bolts for the front sway bars mount only have one bolt on each side showing and no hole for a second bolt.(see attached picture of driver's side - the passenger side is identical).
    Has anyone ever seen this before? Suggestions on what best to do to be able to install a front sway bar?
    Thanks!
    Chet
  2. #2
    Jedi Warrior red57's Avatar
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    551
    Thanks Thanks Given
    7
    19
    Thanked in
    Re: Front sway bar mounting?
    There are supposed to be welded captive nuts on the inside and the material is too thin to drill & tap and expect any real strength.
    Hate to say this but I think you have no choice but to cut the plates off and weld new ones on.
    Moss lists them for $15.99ea and British Car Specialists's Kilmartin list shows them too (I only have a 2013 price sheet at $13.59 each). I don't know who's parts Moss has but I have been real happy with the Kilmartin stuff I've used.
    So, good news is it's not expensive parts, bad news is it's a PITA to do.
    Alternately, if you have fab capabilities, make your own plates. I made mine using 3/16" plate (stock is same as frame at about 1/8" thick) for a stronger mount because I run a 7/8" sway bar.
    Dave
  3. #3
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,753
    Thanks Thanks Given
    50
    34
    Thanked in
    IIRC, the bolt holes are in the middle of that piece (left to right). Is there filler covering the holes?
    John, BN4
  4. #4
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,509
    Thanks Thanks Given
    9
    39
    Thanked in
    This might be a little overkill, but once and done, right!
    I'm reasonably confident that the bolts haven't pulled out, nor the pads caved in or dented during the past nine (<9) years...
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Coupe EB w/ ES/TS & 99 M Rdstr BK/BK
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    16 X5M/DINAN Stg II Mineral White Metallic Wife's 716 hp/702 Lb-ft Turbo Hauler
  5. The Following User Says Thank You to Randy Forbes For This Useful Post:
    Editor_Reid  (02-07-2020)
  6. #5
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,228
    Thanks Thanks Given
    2
    14
    Thanked in
    Basically it comes down to how much time and money do you want to spend and if your doing this yourself or paying to have it done . You can go real cheap and just drill and add sheet metal bolts or drill and install rivnuts where you need them , cut out metal and weld in something etc etc etc .
    Your wallet your decision.
    Randys solution to me is overkill as adding what looks like 3/8 plate to 1/8 frame rails is kinda pointless as its like armour plating a coke can lid and expecting it will add strength. The mounting point for the sway bar will be around till time forgot but the frame rails will be long since gone .
    JMHO .
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnett Kingston 2013
  7. #6
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,444
    Thanks Thanks Given
    14
    17
    Thanked in
    I had to get new plates welded in on my 100 years ago, didn't measure but I seem to recall the replacement pieces being slightly thicker than the surrounding frame. The first couple welders I contacted didn't want to do it (liability) found a small shop that normally did other types of work run by an older guy who I think got a kick out of working on the old Healey, and charged a very reasonable price for the work.
    I don't think I would try attaching the sway bar mounts without something substantial like a welded on nut to keep things in place.
  8. #7
    Join Date
    Feb 2003
    Location
    Posts
    4,509
    Thanks Thanks Given
    9
    39
    Thanked in
    Quote Originally Posted by Healey Nut View Post
    JMHO .
    Hardly! I wanted something thick enough to tap, allowing a minimum of five (>5) threads of engagement.
    Sure, I could've used 10 gauge (.120") I have a ton of it around__well, at least 1/4-ton (500 Lbs!)__and welded a couple of nuts to the backside, but I prefer to NOT duplicate a known engineering failure.
    Coincidentally, it was a career automotive machinist (FOMOCO) that I did the work for, and he was quite pleased at the concept and result.
  9. #8
    Join Date
    May 2015
    Location
    Naples, FL
    Posts
    186
    Thanks Thanks Given
    1
    2
    Thanked in
    Thanks everyone (as always) for your responses and excellent advice. Always very appreciated!
    John you raise a very good question as to whether there is some filler covering the other holes - I'll certainly pursue that option first! Not for the last time I'm wondering what "activities" my Healey went thorough before I got her. Why would both rear locating mounting points be no longer there (or covered) but both front ones be ok? Unfortunately the PO who had the car longest is no longer around to ask....
    Did all 100-6's come with front sway bars installed or where they just produced with the mounting points available and left up to the owners to install if they wanted?
    Randy - great to see you back on the forum!
    Thanks!
    Chet
  10. #9
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,112
    Thanks Thanks Given
    5
    56
    Thanked in
    Wonder what caused the huge dent (top photo) near the rear bumper bolt tube? Someone let the suspension drop hard?
    Top photo shows hideous external rust, but what's visible on inside looks pretty good. That's encouraging.
  11. #10
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,753
    Thanks Thanks Given
    50
    34
    Thanked in
    Quote Originally Posted by Chet Zerlin View Post
    Chet
    The all came with anti-sway bars standard. The mounds often die because of slamming into curbs when parking. The factory rally cars had guards for the mounts.
    John, BN4
  12. #11
    Join Date
    May 2015
    Location
    Naples, FL
    Posts
    186
    Thanks Thanks Given
    1
    2
    Thanked in
    That makes perfect sense John and I think explains why my front bolts are still there while the rear bolts are not since I assume that the rears would take the full force of that impact. Matches what is shown on Randy's too.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
