Bruce Uchida Front Tilting Bonnet, 2008
twas_brillig
http://www.britishv8.org/Other/BruceUchida.htm
"Custom designed and fabricated bonnet hinges that pivot and move the bonnet forward as it opens up. (With these fitted, the back of the bonnet doesn't rub against the bulkhead. Dzus fasteners hold the bonnet down.)"
The above article was published in 2008, and I'm really intrigued by his forward tilting bonnet, as it's probably the most tasteful/subtle I've seen. Does anyone have any information on the design? Drawings???? I couldn't find anything on the Internet with any additional information. Thanks, Doug
Jim_Gruber
Looks like and expensive design to fabricate. With my present front tilt setup the L Bracket can pivot and rock forward when the bonnet is opened. When I close the bonnet I need to rock the L bracket back so bonnet can go up against the bulkhead. When lowering, bonnet will typically want to move to one side or another and not come down straight. I find with Bugsy's bonnet best if I stand on the DS to lower the bonnet and make sure lower edge of the bonnet does not contact the top of the inner fenderwells. Already have some gouges to fix on my paint, but with Rustoleum, fixing is very simple and almost painless. IF I had spent major money I would be crying after the first time the bonnet went down and nicked the top of the inner fender.
Rut
I got so tired of the bonnet shifting in every direction that I finally decided to come up with a cheap solution that’s easy to make. I bent the entire rear lip of the bonnet so it’s at 90*, added some self adhesive rubber weatherstrip along the cowl and installed a HDPE strip with a groove cut in it to position the bonnet. The HDPE has a groove with a 35* entry ‘ramp’ to guide the bonnet into the right position every time and it works. I also installed some semi hidden latches in the front wheel well that lock the bonnet into place side to side and keep it there.
Rut
Bayless
That does fit nice and I like those hidden latches.
T
twas_brillig
Rut - is there a part number or description for the HDPE strip? Or did you cut the groove yourself? And any special advice regards sourcing latches that fit behind the wheel. Your public wants to know.... Thanks, Doug
Rut
Doug,
I just bought a sheet of HDPE 3/4” thick stock and cut it to length, height and sanded a little off so it would fit in the lip on the cowl. I think I bought a 1’x2’ piece if you want me to mail you some since I have more than I will ever need. The latches can be mounted in the fender well up or down since the hook part swivels and adjusts for length. https://www.ebay.com/itm/SOUTHCO-A1...917194?hash=item48cad9ceca:g:-fkAAOSwqzJc9dYH
Rut
T
twas_brillig
Thanks Rut, but no thanks. We probably won't go the front tilt thing, but figured I should at least find out how to do it right. And it'll be a few more months before we fish the Bugeyes out to see the light of day again. Thanks again, Doug
BlueMax
Nice fit on he forward tilt bonnet Rut. Would you have any photos of how you bent the hood and how the HDPE sets in the cowl? Thanks
Rut
I’m in the woods until Sunday afternoon and will post some pictures when I get back.
Rut
Rut
Allen,
Sorry I’m so late getting these pictures...down in the back again. I should have finished the body modifications before paint! The bonnet edge now points straight down and fits into the hdpe slot that has about a 35* angle cut in the front followed by a groove that accepts the bonnet edge. I have rubber weather strip along the cowl that the latches snug the bonnet up to. I cut the hdpe the correct height so the bonnet can rest on it and not just the edge flange. Depending on how wide you want the gap the groove can be cut closer or further away from the cowl. It’s very simple and works every time.
Rut
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
AngliaGT Happy Birthday Bruce MG 2
Basil Bruce Bowker - question RE: Your Caterham 7 Lotus 4
Sherlock Bruce Bowker... great picture! British Motor Corp 2
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
FrogPond "57 100E Front Hubs on E494A Spindles ? Other British Cars 6
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
