TR2/3/3A Gearbox Oil Improvement
ckeithjordan
I just finished replacing the engine/gearbox/OD/differential fluids, having put a 1000 miles on the rebuilt drivetrain. Aside from my travails with the oil filter canister (separate thread), I'm most pleased with swapping out SAE 30 non-detergent motor oil for Redline's MT-90 GL4 gear oil. I immediately noticed smoother, quieter shifting. It was an amazing difference!
CJD
Yes...that’s what he meant with OD! My OD would stick engage on 30w non-detergent. The Redline loosened it right up.
mastaphixa
Bronze
Is the OD serviced separately from the transmission?
ckeithjordan
ckeithjordan
Not sure if you mean is the oil changed separately, but no. Both the gearbox and the OD have to be drained separately, but are filled jointly.
Was that your question?
C Gearbox oil British Motor Corp 3
S Add ZDDP to gearbox oil? Austin Healey 29
Lin Gearbox Oil Austin Healey 4
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R Gearbox and Overdrive Oil Level Austin Healey 18
D gearbox and OD oil drips Austin Healey 23
B TR2/3/3A Gearbox/OD oil Triumph 12
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
G Gearbox and overdrive oil change Austin Healey 15
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
C 3000 gearbox oil Austin Healey 4
K TR2/3/3A 70/90 Gearbox oil and Synchros degrading? Triumph 5
Lukens Best gearbox oil... with overdrive? Triumph 16
P Engine & Gearbox Oil Austin Healey 3
memphis Gearbox Oil Seal Austin Healey 9
memphis Gearbox Oil Austin Healey 15
MadRiver Multi-grade oil in gearbox? Austin Healey 2
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
mgnewbie Oil dripping from gearbox MG 5
nicko oil in gearbox Austin Healey 10
V Oil capacity of Datsun gearbox Spridgets 1
V Datsun gearbox: what kind of oil do you use? Spridgets 10
A Vexing gearbox oil leak Austin Healey 5
C Need info on gearbox and rear end oil for midget Spridgets 5
dklawson Spitfire Spitfire - Gearbox & Oil Pressure? Triumph 17
R Gearbox oil 100/6 Austin Healey 5
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
D Gearbox Oil Lotus 7
OregonTR4A Adding gear oil to the gearbox? Triumph 8
R gearbox identification help & required gearbox oil Spridgets 4
HEALEYJAG BN1 Gearbox oil Austin Healey 9
J Gearbox front oil seal Spridgets 8
Wana Gearbox and differential oil change Austin Healey 8
B gearbox oil Triumph 8
mylillooker Gearbox Oil/Fluid/Grease Spridgets 6
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
Woodie gearbox oil Spridgets 13
C Gearbox Oil leak? MG 10
G Gearbox oil leak? MG 3
dkj313 76 gearbox oil MG 3
DerekJ Gearbox oil level and over-filling Austin Healey 11
Z Gearbox oil and other notes by chris dimmock Austin Healey 2
B Wedge TR8 Gearbox Oil Triumph 5
sparkydave Gearbox oil question Spridgets 4
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
TNMGB Checking/adding gearbox oil?? MG 34
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
S gearbox oil Spridgets 5
J Gearbox Oil Fill? MG 16
