Facet pump died
bugedd
Took the car out for the first time in a while, thing drove okay for a bit, then sputtered, coughed, and died. Then it fired up, drove a bit, did the same thing. I made it home and watched the fuel pressure gauge, and it slowly dropped from 2psi, then back up, so it looks like the Facet died. Is that common with the Facet pumps? If so, I'd like to change to something reliable.
1974MGMidget
Seems like Facets are generally reliable, but even the most reliable pumps will die at some point. If you decide that it is, in fact, the pump, why not an SU pump rebuilt by Dave DuBois? I've been running one for several years now with no problem (yet!). https://userwebs.donobi.net/sufuelpumps/
Before getting the rebuilt pump, I had a minor incident that involved changing a fuel pump in an Illinois corn field. After that, I added a back up Facet in addition to the rebuilt SU. So far, haven't had to use it, but I do check it every once in a while. There seem to be several choices these days, and I'm sure you'll get some feedback on the others, like Airtex, etc. Good luck.
nomad
I'm wondering if your fuel filter is plugged or you have an air leak before the pump. Facet's are noisy but fairly reliable. I did have one that would lean out under hard acceleration though.
Kurt.
bugedd
bugedd
I found a facet in stock local, so I put it in with a new filter. Its much louder than the previous one which I find odd.
dklawson
When installing the metal cube Facet pumps, pay attention to their request that it be mounted at a 45 degree angle. The following is hearsay from another LBC owner but I have no reason to doubt it. Apparently the steel slug moved by the electromagnet in the Facet pump is prone to sticking if mounted horizontally or vertically but lasts longer when mounted as described on the installation instructions.
I have spare Facet pumps rigged with alligator clips and about 3 feet of fuel line in the boot of the Mini and our GT6. It won't take me long to bypass a dead pump and clip one of these in place should I ever have to.
Bob Claffie
In my MGB I added a BARR brand pump (about $15) in line with the original pump and switched separately. Both pumps are flow through pumps so if either one quits the other will function correctly. Bob C
Pythias
I've had my facet in for about 15 years, but I have a brand new Airtex sitting in wait.
bugedd
bugedd
Had an Airtex in the last car, was nice and quiet. May change to that at some point to quiet things down. Weather is too good right now to order something and be without the car.
SD Bugeye
Facets are excellent pumps. But debris of any kind in fuel will kill them.
if scale - rust get into them it can pound into the ball seat and they can't hold pressure.
i have run one for years with a large high surface area filter prior to the pump.
nomad
I've got a pile of SU pumps that I'll never get around to working on. I'm sure some of them would be good with nothing more than cleaning the points. I'm wondering if anyone offers a rebuild service and might want them.
Kurt.
dklawson
Dave will rebuild them for you. He may even offer to buy them as cores.
nomad
Well, i don't think I want to dig through the snow to get to them right now but how do I get hold of Dave Dubois?
John_Progess
I talked to Dave a couple of weeks ago and he is laid up with a bad shoulder for a while but is accepting work for when he is able. His phone number is 360-479-0462 and he lives in Bremerton, Wa. Have a good day!
John
tomshobby
I mounted a Facet pump as a back-up. I also used rubber standoffs and can hardly hear it run.
1974MGMidget
Here is Dave's website, some good information there: https://userwebs.donobi.net/sufuelpumps/
Also, an MGB transmission mount (413-050) makes a good Facet mount. The two studs match the mounting holes in the pump and there is only one stud for mounting, if you already have a suitable hole somewhere. But, it may not be as compliant as the standoffs.
nomad
Thanks for the info on Dave....i'll make a note of it.
Kurt.
Billm
Ed
Check/fix the ground on the Facet and I will bet that it will run for years more
BillM
bugedd
bugedd
I already replaced it, but the ground looked good. Maybe I'll dig it out of the recycling and hang on to it.
Bayless How do you mount a Facet fuel pump? Spridgets 10
steveg Facet pump - explanation for superiority over SU Austin Healey 13
TulsaFred Airtex vs Facet fuel pump Spridgets 29
drooartz MGB-GT Facet fuel pump location MG 11
AH67 facet fuel pump never stops ticking. Austin Healey 6
Lin Facet Fuel Pump Spridgets 18
R Facet fuel pump MG 4
R GT6 Facet Fuel Pump Alternative [GT6] Triumph 4
T Normal for a Carter/Facet pump to be hot Triumph 11
Sebring222 Facet Fuel Pump Other British Cars 9
athenssprite Facet fuel pump - for use on 1960 BE Spridgets 16
healeynut Fuel Pump - Bendix/Facet Austin Healey 0
healeynut FACET Square Body Pump Woes Austin Healey 4
C Facet fuel pump Austin Healey 6
roofman Facet electric fuel pump - need advice Triumph 15
Sarastro Facet fuel pump question Spridgets 5
aeronca65t Facet, Purolator fuel pump MG 11
G Facet pumps any good? Spridgets 23
drooartz MGB-GT Facet vs SU fuel pumps MG 18
dklawson Metal vs Plastic Facet Pumps ? Spridgets 2
sparkydave Facet fuel pumps reliable? Spridgets 23
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
M 1500 Midget water pump weep hole Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
D MGB Fuel Pump MG 2
M Smog pump and alternator brackets Spridgets 0
Martinld123 Electric Fuel Pump Austin Healey 6
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
KVH General Tech Oil Pump Woodruff Key Triumph 10
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
NutmegCT Tire pump in reverse? Restoration & Tools 5
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
KVH General Tech Water Pump Triumph 3
A Spitfire Fuel Pump Triumph 5
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
