TR2/3/3A TR3A Fuel Pump Refurbish
mapleaf
As part of my fuel pump rebuild I would like to remove 25 years of grunge and renew the appearance of the pump body. Any advice on what to use to get the best results will be greatly appreciated. TIA
PeterK
It's under $20 a can here. Comes in a gallon paint can complete with wire basket. Wear gloves, good ones. At your local FLAPS.
M
mapleaf
Thanks guys, I must admit it's the first I've heard of 'dipping type carb cleaner'. Just wondering if it is any more effective then multiple applications of the aerosol spray cleaner.
sail
A few squirts from a $4 squirt aerosol and your spouse’s toothbrush.
TR3driver
Great Pumpkin - R.I.P
It varies, but some of them are much more aggressive than the typical spray. I used some stuff years ago that would clean the skin right off of your hands in just a few minutes. But I think it's illegal in CA now.
Even the spray cleaners have gotten a lot milder since they basically outlawed methylene chloride and perchloroethane.
Moseso
I've always used lacquer thinner to clean carbs. It seems to do a fine job of dissolving old fuel deposits. Of course, I've always worked in wood shops where it was easy to come by -- always in stock. I don't know about CA anymore, but any hardware store around here has it.
M
mapleaf
Well, I've got lacquer thinners and a half can of aerosol carb cleaner in the garage so I'll try both separately and check the results before I go searching for the dipping type cleaner. thanks again
rlandrum
I've used the dipping type. The results were... unimpressive. I found the dremel to be one of the best cleaning tools. They make little abrasive sponge wheels (brown, black, and purple) that remove anything and leave a very nice finish.
That, plus the dremel wire wheels for the tight spots. I suspect a good stiff toothbrush and some carb cleaner would have a similar effect.
Once cleaned, wipe down with a good prep-all pre-paint cleaner. Brake cleaner works too.
On the larger items, I tend to prefer the wire wheel of a bench grinder. Difficult to manage parts get blasted in the cabinet.
Mkutz
I started out with a 48 hour soak in carb cleaner. Practically no difference than when I put it in.
I then soaked in Purple Power for about 24. I buy this by the 2.5 gallon size and when degreasing something, will soak my part for a day or two. It's also an effective paint stripper too. The fuel pump came out with about 80% of the deposits off, and with a little brush and dremel action, was able to get the rest.
angelfj1
Mkutz: It seems like your going through a lot of trouble. Do you have access to a blast cabinet? If you do, these pump bodies clean up real nice and the pumps are very easy to disassemble.
Don Elliott
I have sandblasted my fuel pump a couple of times as Frank mentions. And also the one I carry as my spare. I also do it on other aluminium parts like the intake manifold, etc. for a quick and easy way to make them look new again.
AweMan
Glass beads it will not remove the aluminum, only the grunge!
SteveTR
Maple,
I am with AweMan on this one. Glass works wonders and won't harm anything.
Here in California we don't have access to great removers. I bet I have tried most.
Cheers.
Brosky
If you really want to make them look good............this is over the top for most, but I was playing with ideas.
https://www.74tr6.com/fuelpump.htm
The kits from TRF were good, but lacked a new pin with clips, the mesh screens and a (EDIT) retaining cup that fits over the seal for the diaphragm shaft. I do have a new batch that were polished at Advanced Distributors and new kits from a great supplier here in NE that have screens, pins and diaphragms and bottom seals made specifically for today's gasolines, so I'll be doing a new page on that very soon. No financial interest on my part.
https://www.maritimedragracing.com/then_and_now_automotive.htm
Mkutz
No, my tool inventory hasn't extended to blasting equipment or a decent compressor. I definetly have that in mind before I start my MGA Deluxe.
TR3driver
Brosky said:
The kits from TRF were good, but lacked a new pin with clips, the mesh screens and a seal for the diaphragm shaft.
That's interesting. The TR3 kit I got from them did include the screen & shaft seal (they even advertise that they've found a source for it). The original TR3 pump did not use a replaceable pivot pin with clips, so that is not included.
PS Glass beads in the blasting cabinet do make aluminum look mighty nice. I didn't bother with the fuel pump, but the clutch and brake cylinders came out like new.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:](they even advertise that they've found a source for it)[/QUOTE]
Randall I don't doubt you at all, but I had several discussions with Albert (Chas son) about that and at the time they were still looking for a source for the steel cups that fit over the seal, but that was about 18 months ago.
And my kits were all for a TR6, so maybe they had screens and seals for a TR3, but everything that came in the kit is shown on my web pages. And as you can see, no screen or shaft/clips.
BUT....there are two seals for the shaft, but no steel cup to replace the one that gets destroyed when you try to remove it to get at the seal.
I got the kits in last week and when my wife gets back with her digital camera, I'll take a picture of the entire package and post it.
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Donald1107 59 TR3A Fuel Pump Triumph 48
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
Anthony_S TR2/3/3A Fuel pump and who knows what else TR3a Triumph 23
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
Bremer TR2/3/3A TR3A fuel pump questions Triumph 15
angelfj1 TR2/3/3A AC Fuel Pump for TR3A Triumph 6
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
T TR2/3/3A TR3A fuel gauge question Triumph 36
PatGalvin TR2/3/3A New Fuel Lines TR3A Triumph 2
tmc TR2/3/3A TR3A fuel gauge Triumph 5
R TR2/3/3A TR3A fuel line Triumph 2
R TR2/3/3A TR3A Fuel sending unit Triumph 3
TR3TR6 TR2/3/3A TR3A FUEL GAUGE Triumph 8
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
bigjones TR2/3/3A TR3A fuel line Triumph 13
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
C TR2/3/3A TR3A Fuel Gauge Triumph 1
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
