PatGalvin
Hey Guys
I need to plan my fuel line replacement while the tub is off the frame. I have a couple questions:
1) Has anyone installed an electric fuel pump under the fuel tank? If so, can you tell me where it was mounted (on frame? On tub? Location? And how did you plumb this up? And do you like this set up? My stock fuel pump was rebuilt and works great.
2) Do you guys think it is safe to use short lengths of flexible fuel line coupled with hard pipe under tank or should hard pipe be bent to fit?
3) I don't have a fuel shut off valve in my engine compartment. Car didn't come with one. Should I replace with a mini ball valve for shutoff, or simply terminate the hard pipe into flex pipe and connect to engine-mounted fuel pump? I am not married to the original brass fuel valve and don't really want to purchase a reproduction.
Thanks for any and all ideas.
Pat
Pat
