banjo type fuel lines--vacuum advance
sp53
Does anyone have a picture of how the vacuum advance line is attached on a tr3 that uses the banjo type fuel lines?
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
J Carburetor Banjo Seals Austin Healey 11
G HD8 Carb Banjo Bolts Austin Healey 2
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
S TR2/3/3A banjo bolts to seal up on the early SUs Triumph 4
NutmegCT T-Series Carb banjo washer leaks? MG 9
Mickey Richaud General MG MG Banjo MG 3
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
Rob Glasgow Carb Banjo Gaskets Austin Healey 8
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
Don_R one for banjo Spotted 0
PAUL161 MGB Early Banjo Rear Question MG 8
vette Banjo Fittings Austin Healey 11
B General TR Unusual banjo pieces for brakes? Triumph 3
mgedit TR2/3/3A Banjo Connectors TR3 Brakes Triumph 4
Johnny Fuel pump banjo bolt 101 Austin Healey 3
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
Johnny SU fuel pump banjo fittings stripped out Austin Healey 19
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
J Help with oil pipe banjo bolt. Spridgets 11
DNK Banjo Bolt Triumph 2
6 Rear brake banjo bolt/61 Bugeye Spridgets 3
aeronca65t Spitfire-Banjo Ben Spotted 0
M_Pied_Lourd Banjo Made Me Do It........ Triumph 11
DNK Intake Banjo Triumph 47
D Modified Banjo Steering Wheel???? Triumph 8
PAUL161 MGB Wanted-Early MGB Banjo Rear MG 15
Lynn Kirkpatrick Cracks in '68 banjo steering wheel MG 9
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
S Minor "Banjo" wheel in a Mini? British Motor Corp 0
angelfj1 HAPPY BIRTHDAY BANJO Triumph 7
M MGB MGB Banjo Rear Hub re and re wire wheels MG 0
drooartz Banjo bolt and washers Spridgets 6
Tinkerman TR 3 A banjo bolt and fuel tank vent. Triumph 1
AUSMHLY Healey banjo steering wheel modified to 15" Austin Healey 8
B Brake fluid leak - banjo bolts Spridgets 13
T Photo for Banjo Triumph 18
T Watch Banjo fly-Live Triumph 11
C Banjo rear, new hub help. MG 4
B Banjo Fitting - Oil Pressure Line Triumph 6
AUSMHLY Banjo vent Drain pipe Austin Healey 16
vping Banjo vs. Tubed rears MG 11
tony barnhill Banjo 3rd Member MG 5
S TR2/3/3A Flexible banjo fuel lines on early tr3s Triumph 0
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
