Keeping the brake and fuel lines nice and bright
ronzet
Good day. Just a suggestion... After examining my brake and fuel lines, the metal tubing ones, and deciding that they are in acceptable condition, I used the 'ol wire brush wheel on the bench grinder to clean them up for use. I noticed that after a few days they began to discolor again. Solution?? After making sure that there are no bends, rusted out spots, or anything to compromise the integrity of the lines, clean them and spray a light coat of clear Rustoleum on the lines. They will remain untarnished.... tape the threads and the flanged ends first, of course. Works for me.. /ubbthreads/images/graemlins/smile.gif Ron
John Loftus
Re: Keeping the brake and fuel lines nice and brig
Hi Ron,
I've even sprayed clear over my new zinc plated lines, and aluminum bits (like shock bodies). The hope is the clear will provide some extra protection from the elements. Just make sure you pick a clear rated for outdoor use or it can yellow over time. Another hint with brake lines is to slide the connector back and put a very small amount of anti-seize where the connector and tube flare contact. This will keep the connector from fusing to the flare over time so you can remove it easily.
Cheers,
John
ronzet
ronzet
John, Is this site great or what??? Thanks for the advice. Great idea. I have also used the clear on my miscellaneous parts, once cleaned, to keep them bright.
Best to you and yours... Ron
wangdango Keeping the heat out? Austin Healey 11
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
R Keeping Cool in Florida Austin Healey 1
D Keeping Bondo cool - Texas style Spridgets 1
M Generator not keeping up? Triumph 10
K Keeping a Flywheel from rusting.... Triumph 13
T Keeping the throttle linkage shiny Triumph 5
J Electric Fans and Keeping Things Balanced Triumph 3
drambuie KEEPING YOUR HEALEY RUNNING COOL....... Austin Healey 23
E Keeping the rodents at bay Restoration & Tools 5
N Keeping cooool !! Spridgets 24
Newkie MGB keeping mice away from my winter stored MGB MG 11
John_Mc Denial not keeping rust away. Triumph 13
SCguy TR4/4A Keeping your TR4 cool? Triumph 13
J keeping the heat out Austin Healey 10
kodanja Keeping up with Traffic Triumph 51
A keeping choke from sliding back in Austin Healey 28
B Keeping doors closed Austin Healey 17
U Keeping Them On The Road Triumph 5
Bret Keeping busy: Cosmetics upgrades. MG 12
B Keeping my top on Austin Healey 6
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
