Keeping doors closed
Brakin80
It's a bit hair raising to pull through a turn and have the door fly open. We've noted that the door latch pin only gets as far as the safety catch on the striker with the doors closed. The door to body alignment is good. We pulled the striker off to ensure that it would mate up with the latch pin properly only to find that the latch opening in the body work of the door was too narrow to receive the striker. Which leads me to believe that the latch is set too far out to allow the striker to engage. If we could bring the latching mechanism closer to the inner panel it would probably work. Was wondering if anyone had any suggestions before we take the door guts apart. That being said, any suggestions on order of disassembly of the door panels and mechanisms would help. It's a 1960 BN7. Thanks.
Keoke
HI Bkn80, if you can move the other mechanism out a bit this is the same as moving the latching mechanism in,Also be sure the draugth excluders are not keeping the door from moving farther in??--Fwiw---Keoke
Dave Russell
Yoda - R.I.P
I guess I'm a little dense, don't quite understand your description.
If, when the door is fully closed & it lines up with it's surrounding edges, & the pin is not inboard far enough to engage the striker hole, move the striker outboard until it's hole lines up with the pin. The holes in the door post for the striker screws are slotted to permit adjustment if the screws are loosened. The screws go into a separate threaded back plate which you can see from the fender well. If the holes are not slotted far enough, use a rat tail file to move the slots. Since the striker itself is also tapered in the fore & aft plane, it could be shimmed further from it's mounting plate. Or the striker plate itself could be shimmed out from the inside door trim plate.
If this is not the problem, the latching mechanism in the door could be shimmed a bit as needed.
I don't understand the part about the latch opening being "too narrow" unless it's related to the striker fore/aft taper. It is tapered in two planes.
Not sure if I have helped or not,
B
Brakin80
Moving the striker out only causes it to 'wedge' into the tapered hole in the door. The latch pin is not inboard far enough in the door. Is there a way to get the mechanism inboard more?
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
Ok, I understand. Yes, there "may" be a way. It appears that something is non-standard in the striker dimensions, the latch dimensions, or the door dimensions.
Not only is the the hole in the door tapered but the latch assembly opening itself is tapered, actually a dovetail shape to match the striker dovetail, which limits engagement depth of the striker/pin & the latch assembly. This means that moving latch assembly inboard will not help as the striker wedge will still bottom out in the latch dovetailed opening.
The latch mechanism itself is mounted to a U shaped bracket. This bracket is mounted to the inner door panel with two screws on top & two on the bottom. Top two are hard to get at the nuts above the U bracket, especially the rear one.
The only ways I can see to get more engagement depth is to either narrow the striker taper, which screws up the chrome, or enlarge the latch dovetail width, probably best.
Another possibility would be to simply egg shape the striker pin hole until it will engage the pin. Not a good idea.
If you are sure that the door will line up with the surrounding metal if the latch is fully engaged, this is the only way I can see to solve the problem. Sometimes, the pin hole in the latch is worn enough to give lost motion of the pin. Worth checking. Maybe if you get the latch & the striker out where you can see exactly what is happening, you can get a better idea of what is needed.
Keoke
Hi Dave/BRN80 I think I know what the problem is.That slotted piece that the pin slides into and rotates to the lock position is very worn so that it can move on its own shaft. Consequently, it never reaches the lock position. A fix is to press all the way down on that slotted piece and then tack weld it to its shaft.---Fwiw---Keoke
Dave Russell
Yoda - R.I.P
Hi Keoke & 80,
I considered this, there are several places in the latch mechanism that can give lost motion. Some of them can be tightened up if the casting is not broken. I discarded this solution because 80 specifically said that the striker was not engaging into the dovetail far enough for the pin to line up with it's intended inboard hole. I'm only going by what 80 said. The pin is spring returned to it's fully extended position so lost motion would normally show up as a failure to unlatch. This should be easy enough to check, as I think, the pin should extend out of the latch housing by .230" to .250" when the door is open. If it does not extend this far, the inside "pull bar" may be kinked so that it is limiting return motion, or the end of the pin might be worn. The pin should retract to near flush with the housing when the handles are operated.
80,
BTW, once the screws holding the latch to the door are removed, the latch can be swung down to disengage the remote handle pull bar, the hole is slotted to permit disengagement.
Keoke
Yeah Dave, I had to mull over the failure description too for a bit.But that shaft is quite soft and over the years the square corners get rounded off creating the lost motion.By the way who has the correct Bypass 160 Deg Thermostat??I have the original 180 units but its too warm out here for them.---Keoke
Dave Russell
Yoda - R.I.P
Hi Keoke,
British Car Specialists claims to have the bypass type of thermostat. They don't say which temperature though.
Moss shows a 160 with sleeve, # 434-155.
Fortunately my BN2 does not have a bypass, so no need for one. The heater, when, it's valves are turned on serves as a bypass. With valves off - no bypass except for a small hole that I drilled in the thermostat flange.
Keoke
OK Dave, Moss has a hard time getting things right so I will check David out next week. Thanks ---Keoke
B
Brakin80
The striker and latch mechanism appear as though they would engage each other. It's not the dovetail of the mechanism that is causing the problem. It's the tapered hole/slot in the door. It's because the latch mechanism is too far outboard at the narrow end of the hole in the door. So is there a way to get the latch mechanism to move inboard inside the door. I know, it's an odd one.
Keoke
BRKN80
They do engage each other but I Think there is so much lost motion it will not move to the lock position. pretty common problem with these old worn mechanisms.---Keoke
OH here is a way to check it.With the latch mechanism firmly bolted down,grab the slotted piece and see if it wiggles in and out. If it does thats your problem it can not move at all given the limited travel of the closing door.
One more test while its bolted down.Apply pressure to the slotted piece moving it towards the inside of the car .You should hear two distinct clicks. First safety latch position second lock position.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
There may be a way. Remove the latch mechanism with it's mounting bracket & see if something can be moved, shimmed, to get it further inboard. You are going to have to take it out anyway. Also consider enlarging the tapered slot in the door face until the dovetail will go far enough to engage the pin. Normally, the tapered door slot is noticeably wider than the latch dovetail slot & should not cause a problem. If you get it to latch, final door alignment can be done by moving the dovetail post in it's slotted mounting holes.Yes, it certainly IS an odd one.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
BRKN80
[/ QUOTE ]
Keoke,
We may be talking about different latch designs. The way I understand it, it is not the BJ7, BJ8 design & not the BN2 design, but a variation that is much more like the BN2. The latch bolt is a simple round sliding pin with a chamfered end that engages a corresponding round hole in the striker. There are certainly enough differences of terminology in this discussion to confuse anyone. I can't recognize anything in your description that matches the type of latch that I think 80 has. What slotted piece are you referring to? Who's on first? I'm lost!
Keoke
Yeah, If its not like BJ8 I do not know what is wrong with it . But it certainly would not have left the factory that way.---Keoke
Richard_Trocchia
I installed a new shut face. The pasanger door is fine but the driver side is a problem. The latch does not engage the striker fully and the door then is only on safty latch. I have tried everything to reposition. I broke the roll up window tring to give the door a little extra shove. The shut face (Moss) I think is the sourse of the problem. IShould I rip it out and try something else? R.Trocchia
Dave Russell
Yoda - R.I.P
Hi Richard,
On the older style Healey latches & even on modern cars, the striker is adjustable for position on the shut face. (slotted holes for the mounting screws on the shut face) Even my Toyota has this adjustment. Not so with your latches? Maybe you need to lengthen the shut face slots a bit. Or if there are no slots, make some.
For some reason, on my BN2, I had to lengthen the slots a bit to move the striker to where the door would correctly latch & still be flush with the body.
Keoke
Hi Richard, I take it that your car is a BJ. I would not go to all the trouble to remove the shut face panel at this time.If you have not glued the Draught excluder in try removing it and getting the lock to go to the lock position. Also as I mentioned earlier the slotted part that the pin engages and rotates to the safety and lock position can be worn to the point it may require welding to position it on its shaft correctly.---Let me know how you fare---Keoke
wangdango Keeping the heat out? Austin Healey 11
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
R Keeping Cool in Florida Austin Healey 1
D Keeping Bondo cool - Texas style Spridgets 1
M Generator not keeping up? Triumph 10
K Keeping a Flywheel from rusting.... Triumph 13
T Keeping the throttle linkage shiny Triumph 5
J Electric Fans and Keeping Things Balanced Triumph 3
drambuie KEEPING YOUR HEALEY RUNNING COOL....... Austin Healey 23
E Keeping the rodents at bay Restoration & Tools 5
N Keeping cooool !! Spridgets 24
Newkie MGB keeping mice away from my winter stored MGB MG 11
John_Mc Denial not keeping rust away. Triumph 13
SCguy TR4/4A Keeping your TR4 cool? Triumph 13
J keeping the heat out Austin Healey 10
kodanja Keeping up with Traffic Triumph 51
ronzet Keeping the brake and fuel lines nice and bright Austin Healey 3
A keeping choke from sliding back in Austin Healey 28
U Keeping Them On The Road Triumph 5
Bret Keeping busy: Cosmetics upgrades. MG 12
B Keeping my top on Austin Healey 6
algot1901 Putting the doors on Other British Cars 11
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
Healey Nut Aluminum doors Austin Healey 7
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
H Healey Doors Austin Healey 5
S TR2/3/3A body work on doors Triumph 5
R Bugeye doors Spridgets 11
Jim_Gruber Adjusting Spridget Doors Spridgets 4
P Doors won't stay open [1959 100-6] Austin Healey 16
bighealeysource Best way to adjust doors Austin Healey 9
BlueMax Doors Finley Hung Spridgets 11
BlueMax Ready to hang doors! Spridgets 9
DanLewis Bugeye parts lot: hood, doors, seats, and more - $650 [NFI] Spridgets 0
DanLewis MG Midget doors, hood and trunk $150 [NFI] Spridgets 2
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
B WOO HOO! Doors are finished! Finally got the panels on, door pulls, handles & cranks Spridgets 9
drooartz MGB Making some progress with the doors MG 5
J New wood pieces for the doors Triumph 9
N BN1 Rockers and Doors Austin Healey 11
Bremer TR2/3/3A TR3 half doors Triumph 11
A TR2/3/3A TR-3A rubber trim on doors Triumph 7
T TR2/3/3A TR3B doors Triumph 3
A Adjusting BJ8 Doors Austin Healey 5
R 100-4 doors Austin Healey 3
A TR2/3/3A 60 TR3A doors latch parts Triumph 2
W any tips on removing doors on 100-6 Austin Healey 11
L Doors slam shut Austin Healey 16
