TR2/3/3A I'm going to try some lead repair. Can I do this to my doors?
bnw
I want to add some lead to the door edge areas where I need to close up some gaps. I want to add some lead, say less than 1/16 inch to part of the door where it meets the scuttle. Ive had the door off at least 25 times working the hinges and the striker and the only way to keep the gap to the rocker level, the gap to the front fender consistent, and the sculpture of the door true to the B pillar and the top of the fender will be to close part of the gap with metal (not that good with the MIG) or, I'm hoping with solder. What do you think?
TFB
1/16 isn't much,but lead doest build up thin panel edges very well.Probably no problem if your comfortable working lead.Im more familiar with welding and would sand down the area and have a welder do a little build up that you can grind to shape.
Tom
Brinkerhoff
Barry, if you are talking about just building the edge up with lead , then welding with your MIG would be the best idea . If you could tin both sides of the panel where the skin wraps and fair the lead out a bit so its not just a clean line between the steel and the lead edge that would be the best approach with lead . You need the surface area to work to hold it in place.
Kevin
B
bnw
Understood Kevin, thanks. I almost stopped off to see you today. Not sure you're open yet. I'll try to post some pictures tomorrow. I'd sure like to finish this car sometime.
CJD
Oh, I misread...I would not consider building up the crimped edge of a door panel with lead. It's too soft and there is not enough area for it to hold on. I thought you were referring to the "B" pillar behind the door. From the 3 TR3's I've taken apart, it's obvious that the factory corrected the door gap using lead on the "B" pillar...and the rear valence to the quarter panels. Working lead is one skill I've never learned...but I'd like to!
Brinkerhoff
Barry , sure stop in anytime ! I'm still breaking ice away from the garage doors to get the TR3 out for the spring but I'm hopeful by mid June I can get that done.
martx-5
I agree. I used lead in my resto, mostly over welded seams on patch panels and areas at the edge of a panel, but not the edge itself. I learned how to lead as I went along, and it is a bit tricky, especially on vertical surfaces. There is a fine line between having the lead solid, liquid, or in the peanut butter stage necessary to work properly. The correct lead alloy is 30/70. Anything else has too narrow of a plastic temperature range and is virtually impossible to work with.
Also, do not sand lead. You don't want the dust flying around. You have to use body files, sometimes called vixen files. Another problem I ran into in the beginning is not getting enough lead down in the area you're working. You start filing and realize that there are some low spots. Well, you just can't add more lead as you will be melting all the lead underneath. So, basically you're starting the repair over again.
For a repair such as you want to do, welding is the best alternative.
alanjohnturner
Like you I assumed that lead on the door edge would be too soft and so I used MIG.
BUT
One of the top UK pro-restorers, Stuart Edwards, does public demonstrations of using lead for this exact thing, at big UK TR meets. I think this is also on video.
He swears this is the best way of fixing gap problems. He's the kind of guy that is usually right.
jlaird Going to try something Spridgets 17
G Try going back to Vacuum Advance...Off Intake??? Triumph 7
DerekJ Batteries Going Dead Austin Healey 9
P Spitfire Going up-Engine with my Herald Triumph 6
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
drooartz MGB Made a decision, my MGB is going... MG 102
tahoe healey Backfiring Going Downhill Austin Healey 19
T This is going to be a huge amount of work, yes? British Motor Corp 4
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
R General TR Anyone going to TRA in North Georgia? Triumph 0
pbraun Carpet going in the bugeye Spridgets 12
KVH General TR Headlight going out Triumph 9
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
K TR2/3/3A It was all going so well....... Triumph 11
Magyar Generator going on the fritz Spridgets 3
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
SD Bugeye Going digital Spridgets 4
H Anyone going to the Fall AACA Meet and Flea Market over the next several Days? Austin Healey 2
S TR2/3/3A Transmission not going in Triumph 17
C Going topless Austin Healey 3
PAUL161 MGB The Wife's 72 is Going MG 9
Steve General TR VTR 2015... Anyone Planning On Going? Triumph 0
N BJ8 Noise when going from reverse to forward Austin Healey 2
JPSmit MG 2015 - anyone going [or coming] repost from MG board Spridgets 1
JPSmit General MG MG 2015 - anyone going? MG 12
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
Got_All_4 General TR Roadster factory summer party who's going? Triumph 6
Simmo MGB Going insane with LH Overdrive MG 2
sqbsprite TR6 Anyone from the Carolinas going to TRF's Summer Party? Triumph 6
H Going to Hershey this week and anyone need anything for a Longbridge? Austin Healey 1
drooartz MGB Drew's going to build an engine this winter MG 13
Lukens TR2/3/3A Distributor... going back to points. Triumph 8
JPSmit No, i am not going to look. Spridgets 12
Got_All_4 General TR Who's going To TRF Summer Party? Triumph 3
PAUL161 T-Series Engine rebuilds going up in price! MG 14
TR4nut General TR Kastner Cup 2013 - who's going? Triumph 7
Tugboat Anyone Else Going to the UBSCC Show in Dixon, CA on the 19th? Triumph 4
RickB Looks like I'm going to be driving to South Dakota again! Spridgets 12
W This guy is going to be disappointed... Spridgets 23
dougie !966 Sebring /LeMans "Works" Sprite Going to Auction Austin Healey 2
J Going Racing at the Sonoma raceway this weekend! Racing 5
HealeyRick Goldie Going to Auction Austin Healey 11
T Empty pickup going between Albuquerque and Las Vegas, NV this weekend Triumph 0
M_and_P The Mini is going to SEMA British Motor Corp 4
M Who's going to Triumphest? Triumph 0
J going to Roebling Road this weekend Racing 6
J Going to Thunderhill in Willows this weekend Racing 15
A Going to Drain the gas tank..is there a 'best way' Triumph 24
Got_All_4 Who is going to TRF's Summer Party? Triumph 4
