Backfiring Going Downhill
I recently read somewhere that backfiring going down hill is a sign of too rich or was it a sign of too weak mixture? Anyone know? Car runs well and Colortune shows Bunsen blue on cylinders 2 and 5 (I have two sets).
Rob Glasgow
Re: Backfiring goin down hill
My car has always made a sort of popping sound, off throttle, going downhill. Not a real loud backfire as I've heard other cars. More a pop, pop pop. Exhaust is tight and exhaust pipes shows black soot. No oil burning. Does that sound like too lean? It runs well.
My BJ8 does too. My BN2, which I'm pretty sure has a leak-free exhaust system, does a little less.
'Aficionados' of modern cars--V8s in particular--go to great lengths to achieve rumbling/popping on lift. Apparently, the engineers of the Mustang GT350, with the flat plane crankshaft, were very proud of some overrun popping that sounded like machine-gun fire, after you wound it up and lifted (redline for that car was, IIRC, 8,200 or 8,400RPM). My '19 GT has an 'active exhaust,' which can emit substantial explosive noises in some modes.
tahoe healey
Timing is at 15-16 degrees. I don't know what RBCC is so I am not a member. (Grocho Marks said he would not be in any club that would allow him to join)
I just had a moment of clarity (I think) Reno British Car Club right?
steveg
I have a test hill up my street.
Experimenting with richness, I found it takes very little lean adjustment (maybe 1/2 turn) to induce mild backfiring going downhill. On my car a bit of a burble seems about right.
DerekJ
Popping is not the same as backfiring and is usually the result of raw fuel igniting in the exhaust. Happens more on performance engines as the valves lift higher and are open longer, fuel comes in and flies straight out of the exhaust valve when lifting off. I imagine too rich a mixture could contribute to this.
mgtf328
I've experienced this problem coming down hill. It's a pop, pop burbling sound not a backfire. I eventually discovered that the hose from the manifold to the brake servo had broken off at the manifold clamp letting air in when you take your foot off the throttle. Someone trimmed the hose off too short and it eventually gave way. Check all the connections to the manifold to see if they leak including vacuum advance.
Performance cars with turbos backfire on easing up after hard acceleration. It takes a little while for the turbo to slow and the excess fuel is dumped into the exhaust. This a different from the popping sound.
AJ
steveg
Tahoe,
Next time, pull the choke out a little. If the sound goes away, it was running lean. You just richened it.
Air leaks of the sort mentioned above would also make it lean.
LarryK
Lean backfires thru carbs, rich backfires thru exhaust.
tahoe healey
Thanks all. A lot of good information. It is popping. My concern is being accused of causing a fire as I live in the forest in California.
Theoretically possible, but not likely (unless you're driving off-road in tall, dry grass). Much more likely is some idiot in an SUV pulling off to the side of the road in tall, dry grass--which I've witnessed--and his catalytic converter igniting the grass (which, fortunately, didn't happen).
tahoe healey
Ausmhly, if the message is on zddp, the forum will not let me reply to your PM for some reason. I always add one 4 oz at oil change. One can go crazy with this. If the quantity were that critical, then you would need to add it when you top up your oil???? Probably not necessary to add any as it is only really necessary for break in of new tappets and cam. This has been debated for years on this and other forums with no real resolution but the consensuses seems to be Valvoline is good and has it already in it.
Deleted member 26655
AH 3000 same issue. I researched and found a article regarding back firing on the AH. It means your timing is perfect. Long story but he explained it and it made perfect sense.
LarryK
Is it real backfire or a residual fuel pop. On decelaration or downshifting a proper tuned carb car can pop. Supercharged and turbo does the same only louder. If the mifflers aren't expanding from backfire, you might be OK. I run a 3.5 Jag with straight pipes and it does sing and pop. The new MINI S for 2011 would do this and people would go into dealer and complain, so dealer detuned to eliminate along with performance and fuel economy. I have a 15% pully on my 03 MINI S and really pops when cool out. Sounds good going thru town.
Healey Nut
Pops n burbles are normal on Healeys on overrun be it flat down hill or whenever that’s what makes the classic sound of a Healey .
I recently uploaded a new tuning profile into my Aston to fix the lazy throttle response and one of the things the company that writes the program does is add pops n burble to the program if you want them .
They can make it mild to wild spitting flames from the exhaust on downshifts if that’s what turns your crank .
bob hughes
Have you checked the manifold to head connections, I had a similar situation and found that some of the nuts need pinching up.
:cheers:
Bob
R TR2/3/3A Engine stalling and backfiring Triumph 25
KVH General Tech Carburetors Backfiring Triumph 6
M Backfiring through carbs still Austin Healey 17
C General Tech Backfiring Triumph 35
J TR2/3/3A backfiring tr3 Triumph 30
G Rough running and backfiring MG 30
tweety Dry dashpot and backfiring. Spridgets 8
Stewart Backfiring stalling and missing hard starting MG 5
Stewart Backfiring MG 6
Newkie Another Backfiring post MG 2
S TR4/4A 63 TR4 Help needed Missing / Backfiring Triumph 7
Woodie carb backfiring Spridgets 27
jaybird Backfiring MG 22
Atrus 1275 backfiring Spridgets 16
wkilleffer Sputtering/backfiring around left-hand turns MG 4
C tr 3 backfiring into air cleaner Triumph 3
K ran fine, now sputtering/backfiring at speed MG 8
Slider748 TR6 '74 TR6 backfiring / popping Triumph 5
M SU HIF4 Carbs - source of backfiring?? MG 3
X engine backfiring, lack of power MG 13
DerekJ Batteries Going Dead Austin Healey 9
P Spitfire Going up-Engine with my Herald Triumph 6
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
drooartz MGB Made a decision, my MGB is going... MG 102
T This is going to be a huge amount of work, yes? British Motor Corp 4
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
R General TR Anyone going to TRA in North Georgia? Triumph 0
pbraun Carpet going in the bugeye Spridgets 12
KVH General TR Headlight going out Triumph 9
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
K TR2/3/3A It was all going so well....... Triumph 11
Magyar Generator going on the fritz Spridgets 3
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
SD Bugeye Going digital Spridgets 4
H Anyone going to the Fall AACA Meet and Flea Market over the next several Days? Austin Healey 2
S TR2/3/3A Transmission not going in Triumph 17
C Going topless Austin Healey 3
PAUL161 MGB The Wife's 72 is Going MG 9
Steve General TR VTR 2015... Anyone Planning On Going? Triumph 0
N BJ8 Noise when going from reverse to forward Austin Healey 2
JPSmit MG 2015 - anyone going [or coming] repost from MG board Spridgets 1
JPSmit General MG MG 2015 - anyone going? MG 12
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
Got_All_4 General TR Roadster factory summer party who's going? Triumph 6
Simmo MGB Going insane with LH Overdrive MG 2
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
sqbsprite TR6 Anyone from the Carolinas going to TRF's Summer Party? Triumph 6
H Going to Hershey this week and anyone need anything for a Longbridge? Austin Healey 1
drooartz MGB Drew's going to build an engine this winter MG 13
