Going to Thunderhill in Willows this weekend
Jerry
Lemons race. If anyone is going, stop by # 67 a rusty looking Ford Cortina. We will have some fun, but they are putting too many people on the track these days. Keeps everyone slower, but some of those people are crazy.
Jerry
Billm
By "crazy" you are not referring to a weird VW beetle are you? :smile: (He is a friend)
BillM
J
Jerry
You mean crazy Mike! Of course not. I have raced with him many times. But there are some people that forget the race is for fun and cut you off or tap you. Even when they get black flagged, they drive the same. I am just out to have fun, so they can have the road if it is that important.
Jerry
J
Jerry
Dougie,
I sent your video to one of our drivers that has not been to Thunderhill before. Good lessons. I like the track, even better than Infenion.
Jerry
J
Jerry
Well, we did finish the race but had a few problems. The car was overheating, outside temps were 95-97. We had to take the grill off and remount the radiator fan to get more cooling. This may have had something to do with replacing two alternators over the weekend. The closest auto parts store was an Autozone and both only put out 13.2 volts which seems strange.
Crazy Mike did some off road racing in turn 1. One of out guys got off the track in turn 5.
One car caught on fire during the race, but the driver was already out and way.
Our Cortina can get enought speed but does not corner well yet. There is something wrong with the front suspension. We had it aligned but when you jack up the car the wheels toe out away from each other. So it is aligned when sitting on the tires, but as the suspension moves the alignment moves. I watched the guy align the car and the toe was correct, camber was minus 1. Castor was set at 1.25 per tire. Any ideas??
Jerry
DRKizer
Jerry, what you are describing about your front suspension is called "bump steer". Yours seems to be pretty severe if the toe change is that noticeable. Yes, it can make for evil handling. But the good news is that it can be corrected if you put your mind to it. Which model Cortina do you have? MkI? MkII? Do you know any Cortina gurus that may be able to tell you what you are up against to "bump steer" the car?
Cheers,
David
J
Jerry
While it is a MK 2, the front steering has been converted to rack and pinion via an english kit. We aligned as per instructions but it still has problems. Know any experts around Sacramento?
DRKizer
Hmm. Did that kit come with installation instructions that address bump steer? Or, are you just "on your own"?
The mounting point elevation of the steering rack is critical. The length of the steering links that connect the rack to the steering arms at the wheel hub is also critical (To completely neutralize bump steer, the steering rack may have to be either narrowed or widened between the inner ball joints in order to lengthen or shorten the steering links).
You may be able to get at least a feel for what will be involved. You have severe bump toe-in/ droop toe-out. Whether the steering rack needs to be mounted higher up or lower, depends on whether the steering rack is forward of the axle center line or aft of the axle center line. If the rack is forward of the axles, the rack would have to be raised. If the rack is aft of the axles, the rack would have to be lowered. As a wild guess from the severity you describe, the rack may have to be moved up or down an inch or more. You have to get the rack in the right elevation (trial and error) before you can begin to tell if or how much the length of the steering links have to be changed.
I've done a fair amount of bump steer work on production based race cars in my time. I'm located near Medford, OR and will be coming down to Sears Point to crew for a friend at the CSRG Charity Challenge, Oct 5-7. If you will be there, I'll be glad to look at your car and see if there is any more advice that I can offer.
Cheers,
David
AngliaGT
Jerry,
I think that your problems stem from converting to
rack & pinion.
I think that you need to conact Mike Drouin in Lodi.
He knows more about Cortinas than anyone in the Sacto area.
- Doug
aeronca65t
A decent example of bump steer can be seen HERE
Very basically, place your car on the ground and your tie rod should be approximately horizontal (when you are sitting on the ground looking back at the front of the car).
In order to achieve this, you may have to raise or lower your rack.
This is not a precise solution. There are a number of other factors with the suspension geometry.
But it should get you reasonably close.
READ THIS for a decent, simple explanation.
J
Jerry
Thanks group, this is interesting reading and describes the problem well. Now I get to take some measurements. I will try to find someone local to help. Our car is actually in Loomis CA. It was sitting on the ground in a field for years and the original steering was quite rusty. The "kit" we bought was from a guy who races in England and of course came with no instructions. We called him 3 times for more details but what we really bought was a triangle diagram with heim joints and found out that talking to him over the phone was not worthwhile.
The video is describing perfectly what is happening with the car. Makes for interesting driving.
thanks for the suggestions. If you have more, keep posting please. October 6th is out for us to meeting at Sears Point (or whatever the new name is).
Jerry
J
Jerry
Just wanted to give you an update on the Bump Steer issue. We bought some different end rods and were able to flip the connection to under the attachement arm instead of on top. This made the wheel and arm in line with the use of spacers. I also found a old wheel alignment tool that I inherited from my dad and used that to measure the toe changes as the wheel moves up and down. With a little adjustment of the spacers, there is now now movement! Much better. Now we are going to take it to a track test day at either Infinion or Thunderhill and see how it drives. We also were fixing the carb problems and had the opportunity to get the car on a dyno for free. The expert helping us had some changes in timing and adjustments which showed an improvement in horsepower of 18%. Not that it will every be a speedster but we will be entering the next Lemons race at Infinion in March and see how it does.
Thanks for the help!
Jerry
dougie
Nice improvements, keep us posted on your next outing.
DerekJ Batteries Going Dead Austin Healey 9
P Spitfire Going up-Engine with my Herald Triumph 6
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
drooartz MGB Made a decision, my MGB is going... MG 102
tahoe healey Backfiring Going Downhill Austin Healey 19
T This is going to be a huge amount of work, yes? British Motor Corp 4
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
R General TR Anyone going to TRA in North Georgia? Triumph 0
pbraun Carpet going in the bugeye Spridgets 12
KVH General TR Headlight going out Triumph 9
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
K TR2/3/3A It was all going so well....... Triumph 11
Magyar Generator going on the fritz Spridgets 3
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
SD Bugeye Going digital Spridgets 4
H Anyone going to the Fall AACA Meet and Flea Market over the next several Days? Austin Healey 2
S TR2/3/3A Transmission not going in Triumph 17
C Going topless Austin Healey 3
PAUL161 MGB The Wife's 72 is Going MG 9
Steve General TR VTR 2015... Anyone Planning On Going? Triumph 0
N BJ8 Noise when going from reverse to forward Austin Healey 2
JPSmit MG 2015 - anyone going [or coming] repost from MG board Spridgets 1
JPSmit General MG MG 2015 - anyone going? MG 12
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
Got_All_4 General TR Roadster factory summer party who's going? Triumph 6
Simmo MGB Going insane with LH Overdrive MG 2
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
sqbsprite TR6 Anyone from the Carolinas going to TRF's Summer Party? Triumph 6
H Going to Hershey this week and anyone need anything for a Longbridge? Austin Healey 1
drooartz MGB Drew's going to build an engine this winter MG 13
Lukens TR2/3/3A Distributor... going back to points. Triumph 8
JPSmit No, i am not going to look. Spridgets 12
Got_All_4 General TR Who's going To TRF Summer Party? Triumph 3
PAUL161 T-Series Engine rebuilds going up in price! MG 14
TR4nut General TR Kastner Cup 2013 - who's going? Triumph 7
Tugboat Anyone Else Going to the UBSCC Show in Dixon, CA on the 19th? Triumph 4
RickB Looks like I'm going to be driving to South Dakota again! Spridgets 12
W This guy is going to be disappointed... Spridgets 23
dougie !966 Sebring /LeMans "Works" Sprite Going to Auction Austin Healey 2
J Going Racing at the Sonoma raceway this weekend! Racing 5
HealeyRick Goldie Going to Auction Austin Healey 11
T Empty pickup going between Albuquerque and Las Vegas, NV this weekend Triumph 0
M_and_P The Mini is going to SEMA British Motor Corp 4
M Who's going to Triumphest? Triumph 0
J going to Roebling Road this weekend Racing 6
A Going to Drain the gas tank..is there a 'best way' Triumph 24
Got_All_4 Who is going to TRF's Summer Party? Triumph 4
B Who's going up Mt. Washington? Austin Healey 5
R July 15 Fairfield Ohio meet anybody going? Spridgets 8
