Keeping up with Traffic
kodanja
Keeping up with todays faster cars on the highway these days, you kinda feel like you have to race everyone. /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
My questions is what is a safe highway rpm to maintain without pushing your car to hard?
I ask because my speedo has yet to work properly (I'm have been too lazy to repair it yet) /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
My guess would be between 3000 & 3500 rmp's
any feedback would be appriciated.
btw it has the type 9 5sp. conversion installed
(1st = 3.36, 2nd = 1.81, 3rd = 1.26, 4th = 1.0, and 5th = .825)
AweMan
The only thing I have with a 5 speed is my Nissan Pickup. At 3000 R.P.M.. In 5th Gear in it, is 70 M.P.H.. 3000 R.P.M. in my Tr, 4th gear {as I remember} was around 60 M.P.h.
In any case 3000 R.P.M. seems to be a comfortable highway cruising R.P.M. for most engines.
Kerry
Brosky
Just maintain it up about 4800-5000 and you'll be fine......not..
kodanja
kodanja
Thanx Paul, then you can help me put in a new tranny and motor!
AweMan
Hahahahaha ................. I think I was up around 5,500 when I blew the #2 rod bearing out of my Tr-3 {long story why it blew at that R.P.M.} Had to do with a piston being fitted too tightly to the liner. And MABY an extended run at 5,500 R.P.M. {as in raceing someone}.
Kerry
NickMorgan
I guess fourth will give you about 60mph at 3000rpm. I should think there would be no problem at all with maintaining 3500rpm for cruising and pushing up to 4000 and even 4500 for shorter bursts to get past those moderns. After all they were designed to cruise at 70 on British motorways.
achtungeveryone
I use to curse the designers of my '78 subaru brat for not providing a 5th gear. I think the driver has more fatigue at high rpm than the engine. I would like to read in the owners manual of my tr6 : "it's quite fine to run your triumph at 4500 rpm all day should you wish...so long as your nerves can stand it"
Geo Hahn
NickMorgan said:
...I should think there would be no problem at all with maintaining 3500rpm for cruising...
That's been my experience. The 4-cylinders at least don't seem to mind hour after hour of 3500. Our local speed limit is 75 so most traffic is somewhere north of 80 mph. I can keep up but those big rigs look a bit scary from the perspective of the 3's cut-down door (though all I can see is their hubcaps).
Lou Metelko
The type A Laycock overdrive in the 54 TR2 yields a solid 80MPH at 3150RPM. Fells like it can do that all day. I can run with the big dogs but a fully loaded 18 wheeler can whoa down much faster than I! (All 2s have drums F & R).
Lou Metelko
Auburn, Indiana
gsalt57tr3
I'm running 2600 rpm at 65 mph.
Thats with the toyota five speed.
3000 rpm gets me 75 mph. The engine is fine at that speed, but I worry about the rest of the car. 65 is fine
Harry_Ward
That's more what I was thinking too. Fifth gear at 2500 to 2800 rpm to keep it in the legal range of 65 mph on 95 or the Merrit pkwy. Then again, you know everyone will be passing you like your standing still at this speed.
Better opt for 3200 to 3500 /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Andrew Mace
A stock Herald 1200 sees around 16 mph per 1000 rpm in top gear. So, at or near 65 mph, that's a bit over 4000 rpm ... which my Herald was happy to do, hour after hour, to and from Minnesota. That round trip was a total of around 2500 miles, most of which were on the Interstate at 60-65 mph. Didn't bother me or the car one bit.
Overdrive might have been nice for better fuel economy, but I got 33-35 mpg overall on that trip without it....
Brosky
Andy, the mileage is all in the aerodynamics of the Herald. I've never gotten anywhere near that in the TR6, even with O/D.
Then again, I probably drive too hard and too fast just to listen to the engine and you probably drive sensibly.
Brosky
Alan, I still think that the aerodynamics play a big role in this. Low drag coefficient and all that stuff that racers use.
I've tried to buy two Heralds in the past and have been beaten both times on the bids. I really liked driving one of those a few years back. It was a great little convertible to run around in.
If I try to buy a second British car again, I may wake up missing an important body part, so I'm laying low on that idea for a long while.
G
I'm not seeing a Herald as being any more aerodynamic that a TR6. Neither of them exactly struck me as being designed in a wind tunnel.
I agree that a Herald is a fun drive. I'm not sure about taking one on the highway round here though. I'll do it with the -6, because it can get out of it's own way, but I'm not man enough to try with a Herald...
TheAssociate
The high RPM does really get to me on the highway. Interesting - looking through the Haynes manual for the Spitfire it seems the North American Spitfire generally came with the 3.89:1 ratio rear end, and the European spec shows 2.89:1!!!!!!!!!!!!!
Why would they do this?
Adam.
____________________________________________________________
1973 Triumph Spitfire.
Andrew Mace
Spitfires through the end of the Mk3 model had 4.11:1 diffs. Beginning with the MkIV, they had a 3.89:1 diff (except for the 1972 US-spec MkIV, where the low compression version of the engine required a return to the 4.11:1). US-spec 1500s again had the 3.89:1 diff, while UK-spec, twin-carb 1500s had a 3.63:1.
To my knowledge, there was never any such thing as a 2.89:1 diff in any Triumph. On the other hand, for some markets one could actually obtain a 5.143:1 diff for the Herald, and the 948-engined Standard Atlas Van and pickup had a 6.66:1 diff!
As for the Herald itself, we're talking 40 hp pushing a 1700 lb. rounded brick. I happen to love the style, but I don't think of it as especially aerodynamic (although maybe the rear fins help?). The Spitfire likely is a bit better in that respect.
And I don't know that one has to "be a man" to drive a Herald at those speeds and/or in that sort of Interstate highway traffic. It might just be that I've been doing it off and on for almost 38 years now, or that I do have 38 years of driving in general (most of which has been done in cars that would not set land speed records), or that I do have a pretty substantial background both in varying forms of low-key motorsport activity as well as 12 college credits in driver education. If I'd become a teacher here in NY, I could have taught driver education in a public school. I didn't go that route, but I did spend some time teaching for a private driving school as a part-time job.
wangdango Keeping the heat out? Austin Healey 11
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
R Keeping Cool in Florida Austin Healey 1
D Keeping Bondo cool - Texas style Spridgets 1
M Generator not keeping up? Triumph 10
K Keeping a Flywheel from rusting.... Triumph 13
T Keeping the throttle linkage shiny Triumph 5
J Electric Fans and Keeping Things Balanced Triumph 3
drambuie KEEPING YOUR HEALEY RUNNING COOL....... Austin Healey 23
E Keeping the rodents at bay Restoration & Tools 5
N Keeping cooool !! Spridgets 24
Newkie MGB keeping mice away from my winter stored MGB MG 11
John_Mc Denial not keeping rust away. Triumph 13
SCguy TR4/4A Keeping your TR4 cool? Triumph 13
J keeping the heat out Austin Healey 10
ronzet Keeping the brake and fuel lines nice and bright Austin Healey 3
A keeping choke from sliding back in Austin Healey 28
B Keeping doors closed Austin Healey 17
U Keeping Them On The Road Triumph 5
Bret Keeping busy: Cosmetics upgrades. MG 12
B Keeping my top on Austin Healey 6
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
D TR2/3/3A Traffic at or and horn button not working Triumph 2
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
Steve Citroen SM in traffic Spotted 1
Steve TR2/3/3A Spotted in traffic on Saturday... Triumph 2
DrEntropy 850 Mini in traffic! Spotted 0
B Traffic indicator rotor woes Austin Healey 5
DrEntropy TR-6 in traffic Spotted 3
Bret My Shark ate a traffic cone yesterday.... Other Cars 17
Nunyas Traffic ... it became a good thing this time... MG 26
tony barnhill Building BBS Traffic MG 5
