Generator not keeping up?
M
Member 10617
Took another ride up on the Blue Ridge Parkway today. Ran into a lot of fog and turned my lights on. (Its' very rare that I ever use my headlights).
I noticed that with my headlights on, my ammeter needle moved halfway to the -30 position and remained there all the time that the lights were on. When the lights were turned off, the needle went back to "0".
Does this mean that my generator cannot keep up? And what else may it say about my generator?
TR3driver
Great Pumpkin - R.I.P
What engine rpm? What do you have for headlights?
Yes, the generator was not keeping up and the battery was running down. But that is perfectly normal with the stock generator at idling or low rpm. It takes nearly the full output of the generator to keep up with the headlights, and it doesn't reach full output until 2500 (engine) rpm or so. (Approx 4500 at the generator shaft.)
M
Member 10617
I have HID (xenon) lights on the car. They were on while I was driving about 40-45 mph, at an average of about 2500 rpm, reaching at times 3000 rpm.
TR3driver
True HID (high intensity discharge) or fake?
A real HID bulb only draws 35-40 watts, but there will be a fair size electronic "ballast" for each bulb that turns the 12v into what the arc inside the bulb requires. But there are lots and lots of fakes on the market, that are really just quartz-halogen incandescents. Typically they do generate the high color index (blue-white) light that is commonly associated with true HID, but they also typically draw 2 or 3 times as much power. If you are running 90 watt bulbs, for example, the stock generator hasn't a prayer of keeping up.
One easy way to resolve the issue might be to take the car to some place that will test the generator on the car, including a load test. I'm not sure what they have in VA, but around here, O'Reillys will do the test for free and it only takes a few minutes.
Here is a site that sells the fake HID bulbs:
https://www.everbuying.com/product45669.html
And here is a shot of a typical ballast (which is required for true HID bulbs)
M
Member 10617
Randall,
My HID lights are the real thing, including balast. The folks at the shop that put them in told me that they would draw less power than ordinary headlights. Which leads me to think that there is a problem with the generator ... the alternator... or both.
To be more precise, the ammeter remains at -15 when I run with my headlights on, even at 2500-3000 rpm. The needle returns to "0" only when I turn the headlights off.
I plan to take the car to the shop as soon as possible after Hurricane Sandy finishes its dirty work.
TR3driver
Yup, then you've definitely got a problem. Most likely the control box, IMO, but could be the generator itself.
A TR3A doesn't have an alternator (unless someone has added it), so I'm practically certain it's not the issue :jester:
M
Member 10617
Randall,
Sorry... I meant to write "Regulator" and not "Alternator." The regulator is almost brand new, but that doesn't mean that it's not bad. We'll see.
M
Member 10617
Say now! Here's something:
I checked in the Maintenance & Instruction Manual for Lucas Electrical Equipment, section 2, and found the following:
"A discharge reading may be given immediately after switching on the headlamps. This usually happens after a long run, when the voltage of the battery is high. After a short time, the battery voltage will fall, and the regulator will respond, causing the dynamo output to balance the load."
Yesterday, when I noticed this problem, I had been driving for about 1 1/2 hours before turning on the headlights. After a few minutes, I noticed the ammeter needle at -15 and holding, so I turned the lights off. Perhaps I didn't allow enough time for the battery voltage to fall, causing the dynamo output to balance the load.
Weather permitting, I will check this out this afternoon before the storm hits.
What do you think?
M
Member 10617
What I cited above may have been part of the problem, but I have fixed the problem in a much simpler manner... an embarrassingly simple manner: I cleaned the contacts on the generator and everything starting working normally again.
M
Member 10617
You are right! As I drove down the highway a few minutes ago satisfied that this simple solution was actually THE solution, I decided that I had to change the tag line. The same goes for my fixing my stator tube problem simply by tightening the stator nut.
MGTF1250Dave T-Series Lucas Generator MG 1
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
T Spitfire MK2 Generator Triumph 3
W Generator and Starter Long Bolts Spridgets 0
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
B Generator Parts Austin Healey 6
P BN4 Generator Woes Austin Healey 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
TR3MT TR2/3/3A Generator Output Triumph 18
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
AUSMHLY Generator to Alternator Swap Austin Healey 20
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
O Generator Question Austin Healey 2
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K What to do for coil bracket on upgraded generator? Austin Healey 8
R TR2/3/3A generator to alternator Triumph 5
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
T New Generator Mystery Austin Healey 5
I Bugeye generator/alternator conversion question Spridgets 7
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
R TR2/3/3A TR-2,3 Generator Pic showing all attachments Triumph 5
doc50 Mash Metropolitan Generator testing Other British Cars 1
S TR2/3/3A generator red light deal Triumph 6
J advice on a 3 brush generator please C45N-3 Other British Cars 0
5 Tach Drive Generator for a Bugeye Spridgets 2
M Jaguar XK Special Equipment Generator Jaguar 1
T C42 BJ8 generator long screw needed Austin Healey 2
Magyar Generator going on the fritz Spridgets 3
Rhodyspit75 Generator pulley diameter Spridgets 2
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
Rut Bugeye generator color Spridgets 22
CJD TR2/3/3A Generator and other Odds Triumph 6
G TR4/4A New Generator vs Alternator vs BPNW Alternator/Generator Triumph 13
R TR6 Generator to alternator conversion Triumph 6
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
K TR4/4A Generator bench testing..... Triumph 6
G Generator - Key Replacement Austin Healey 6
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
