TR2/3/3A TR3A fuel line
bigjones
Bronze
Hi folks,
Could someone please confirm that the rubber fuel line that leads up to the glass bowl of the pump is 1/4" ID. The rubber is showing a slight crack and I need to replace it.
I was going to cut the line at the glass bowl, temporarily install a metal shut-off valve (any suggestions?), lower the line down to the ground and then drain out the gas into a container. Any better ideas to reduce spillage?
Then I'll install the new line (with the valve).
I've also heard, over in the Spridget forum, that gas line for fuel injection, though a bit more expensive, is preferable. Any thoughts? The reason I ask is that a while ago I came across little black specs in the carbs that I believe to be from the rubber fuel line.
Also, the PO just had a rubber line from the pump to the carbs - I'm thinking I should get the proper steel line for safety, don't you think?
Cheers!
TR3driver
Great Pumpkin - R.I.P
Mine is 5/16" id, which I believe is correct for the later cars as well.
Best way to reduce spillage is to run the tank nearly empty first. I might even be tempted to use my "backup" electric fuel pump to transfer the fuel to another car.
For just a temporary shutoff as you are proposing, you can just stick your finger over the end of the cut line, or stuff something into the line.
IMO, buying "fuel injection" line is a waste of money. It's made from the exact same 'rubber' as low pressure line, just has stronger internal reinforcement to handle the extra pressure. The issue is that older low pressure fuel line was made from a different material that will not stand up to the ethanol (and other chemicals) found in modern gasoline. But anything made in the last 20 years or so should be just fine.
And either way, it should be replaced every few decades. The stuff just doesn't last forever.
vivdownunder
A drill bit stem pushed down the fuel line is a convenient way to block spillage.
Off the shelf in most garages with all the diameters needed.
Viv.
bigjones
bigjones
Bronze
Thanks for posting Randall - you saved me fighting with 1/4".
Yes, I like that idea!
Jeremy - thanks for the link - I might get some just for that part of the line.
Viv - never thought of that - and I've got plenty of drill bits - all nicely blunt.
Cheers
ekamm
Golf tee works well too.
mrv8q
I'm surprised that 5/16ths seems to be the prevailing number; it's way too large for my just rebuilt carbs. Even 1/4 seems a touch loose; I can easily pull them off and on. I'm using a metric woven fuel line on mine, that hold very tightly w/o hose clamps.
TR3driver
That's because the original question was about the line on the inlet (glass bowl) side of the fuel pump. The line from the pump outlet to the carbs is 1/4" od. The original lines used without clamps were a bit undersize so they would grip; modern line pretty much requires clamps.
TR3driver
jdubois said:
I know Gates recommends using SAE 30R9, which they call 'fuel injection hose', not SAE 30R7 which they call 'fuel and oil hose'.
Hmm, a leading hose maker wants you to buy their much more expensive hose instead of the cheap stuff. You don't think there might be a relationship there, do you?
:devilgrin:
mrv8q
Well, that explains that! True enough, I didn't read the post that carefully.....
Thanks, Randall!
sp53
Hi all I am new to the carbs without the banjo fitting and wonder how they kept them on in the day. I went to the lawn mower shop and purchased some Honda lawn mower fuel (perhaps ¼) line that just pushes on and it holds well on the ¼. The stuff is ten bucks a foot. The problem I am having is at the transfer point from 5/16 to 1/4 at the first bowl. I cannot seem to easily make that stretch with a short piece of rubber. Any ideas? What did they have there on the originals?
steve
PeterK
5/16 flex-line from the steel tank line (and/or shut-off valve) to the stub hard line on the pump, then 1/4 on the carb side of the pump to the carbs.
I used regular fuel line from my FLAPS.
jdubois
:devilgrin:
Sure, gain of salt always needed... but if that was their only goal, you'd think they'd be pushing their even more expensive 30R14 which is *supposed* to be their ethanol safe 30R7 replacement.
R TR2/3/3A TR3A fuel line Triumph 2
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
T TR2/3/3A TR3A fuel gauge question Triumph 36
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
PatGalvin TR2/3/3A New Fuel Lines TR3A Triumph 2
Anthony_S TR2/3/3A Fuel pump and who knows what else TR3a Triumph 23
tmc TR2/3/3A TR3A fuel gauge Triumph 5
R TR2/3/3A TR3A Fuel sending unit Triumph 3
TR3TR6 TR2/3/3A TR3A FUEL GAUGE Triumph 8
Bremer TR2/3/3A TR3A fuel pump questions Triumph 15
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
M TR2/3/3A TR3A Fuel Pump Refurbish Triumph 20
angelfj1 TR2/3/3A AC Fuel Pump for TR3A Triumph 6
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
C TR2/3/3A TR3A Fuel Gauge Triumph 1
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
