TR2/3/3A TR3A fuel line
RonR
Folks,
I have a fuel leak where the old fuel line attaches to my new Roadster Factory fuel tank. The existing fuel line has been cut off rear of where the original union would have occured. A rubber fuel hose connects to the rear fuel line and extendds to the steel fuel line coming from the fuel pump. I plan on getting a fuel line from a local parts store and connecting back to the existing rubber line. Is ther a need for the steel fuel line to have the 180 degree bend that forms sort of a P-trap?
Thanks.
Ron
mallard
I don't have my car in the garage right know so I can't take a look, but I think it was bent like that to go around the axle. No need for any sort of P Trap.
CJD
I just installed mine last week. It comes out of the tank and makes that fairly gentle bend to go back to a clip on the body tub. The clip attaches to a stud that is welded on the body. The "U" shape is needed to get the line to the clip without too severe of a bend. The clip is to take any stress off the union to the tank. I would do it as they originally did.
Mine clears the axle without any problems.
Good luck,
John
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
bigjones TR2/3/3A TR3A fuel line Triumph 13
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
T TR2/3/3A TR3A fuel gauge question Triumph 36
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
PatGalvin TR2/3/3A New Fuel Lines TR3A Triumph 2
Anthony_S TR2/3/3A Fuel pump and who knows what else TR3a Triumph 23
tmc TR2/3/3A TR3A fuel gauge Triumph 5
R TR2/3/3A TR3A Fuel sending unit Triumph 3
TR3TR6 TR2/3/3A TR3A FUEL GAUGE Triumph 8
Bremer TR2/3/3A TR3A fuel pump questions Triumph 15
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
M TR2/3/3A TR3A Fuel Pump Refurbish Triumph 20
angelfj1 TR2/3/3A AC Fuel Pump for TR3A Triumph 6
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
C TR2/3/3A TR3A Fuel Gauge Triumph 1
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
