TR2/3/3A TR3A FUEL GAUGE
TR3TR6
I have a question for the group. Can a TR3a fuel gauge be tested by just applying a 12V source to it? Since it normally receives it's power through the fuel sender unit which has a built in resistance, I was wondering if a 12v high amp source wouldn't just fry the meter. Has anybody tested a meter with just the battery?
PeterK
You CAN test it by measuring the resistance with an ohm meter across the terminals. It should change as the float is moved up and down. But can't remember the ohm correct readings as it swings through its motion. I'm sure someone will chime with correct ohms.
TR3TR6
TR3TR6
Peter:
Thanks for the reply. But the gauge is not wired up to the sender unit. I was wondering about testing the gauge as a stand only unit.
Adrio
I can't remember how long ago, but if you search here in the forum someone posted a link to a good article on testing that guage. I think the article talked about builing a resister box to "calibrate" the guage. Maybe someone with a better memory or the actual article link can chime in. wait, I may have found the link https://mgaguru.com/mgtech/electric/fg_01.htm
TR3TR6
TR3TR6
Adrio:
That's a good article on the fuel gauge, but it didn't say anything about just applying a 12v source to the gauge as a method to test it. Thanks.
Moseso
Also --
The TR3 gauge works "backwards." A full 12 volts makes it read empty, though the needle will come up off the peg. The TR3 sender is high resistance, when full -- low resistance when empty.
One more thing -- as well as hooking up the battery to the terminals, the case must be grounded. The needle will move around if the case is un-grounded, but it won't read correctly. Don't ask me how I know this, nor what the result of that failed experiment was...
MGTF1250Dave
Aloha,
A power source for a simple "does it work" test is a 9 volt battery. The old transistor radio battery with some leads attach will be enough to show you the electric gauge needle will react to power. It will not determine accuracy, but the low voltage and amperage won't hurt the gauge.
TexasKnucklehead
According to my notes:
TR3 fuel sender = 2 ohms at empty (that's basically a short or direct connection)
TR3 fuel sender = 85 ohms at full
So, if you hook one side to a 9v battery (or 12v dc source) and the other to a 85 ohm resister with the resisters other end to the other side of the supply, you should see full. Remove the resister, and see empty.
Early TR4 fuel gauges look the same, but empty=240 ohms and full=30 ohms.
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
D Wanted TR3A Fuel gauge Triumph Classifieds 4
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
T TR2/3/3A TR3A fuel gauge question Triumph 36
tmc TR2/3/3A TR3A fuel gauge Triumph 5
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
C TR2/3/3A TR3A Fuel Gauge Triumph 1
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Donald1107 59 TR3A Fuel Pump Triumph 48
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
PatGalvin TR2/3/3A New Fuel Lines TR3A Triumph 2
Anthony_S TR2/3/3A Fuel pump and who knows what else TR3a Triumph 23
R TR2/3/3A TR3A fuel line Triumph 2
R TR2/3/3A TR3A Fuel sending unit Triumph 3
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
Bremer TR2/3/3A TR3A fuel pump questions Triumph 15
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
bigjones TR2/3/3A TR3A fuel line Triumph 13
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
M TR2/3/3A TR3A Fuel Pump Refurbish Triumph 20
angelfj1 TR2/3/3A AC Fuel Pump for TR3A Triumph 6
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
