TR2/3/3A Boot closeout for fuel tank tr3a
ekamm
Does any one have a rough dimension handy for the boot tank close out forgot to measure this morning. I am going to buy some vinyl to cover one that I'm making.
JohnnyMead
Eric,
Mine is 46" x 14 1/2". The 46" is measured from the very tips of the parts that curve around the tops of the wheel wells. The distance between the wheel wells is about 36".
Vinyl sounds like a good solution. Are you using the kind of vinyl that's on the glove box and dash?
John
ekamm
ekamm
Thanks John. I went to JoAnn's fabric and found the closest thing to the vinyl that is used in the interior. It seems a little smoother than that but if you have the original board to look at it was a hardboard-like material witha the exterior facing the boot a glossy look with some grain in it. So I think that it will look OK. I am going to the thinnest batting that I can find on first with a spray adhesive and then covet with the vinyl. I'll post some pics of the process as I go.
JohnnyMead
I think they just pressed a pattern into the masonite. Vinyl will look better. Have you considered skipping the batting all together?
John
ekamm
ekamm
I feel like the batting will take out any imperfections in the board. I could just stick it to the board. I'm concerned that any warp would be noticeable.
angelfj1
John
That's correct. The trunk millboard (rear petrol tank casing) was "pebble grained" and held to the car by #4 trim screws and cup washers. Initially, these panels were sprayed to match the body color of the car. But, from TS 22014, the millboards were all black.
There was never any vynide covering or batting, just the millboard alone.
ekamm
ekamm
Here's a couple of pics of the original
TR4nut
Eric-
question for you - is there any evidence that the lower edge had a short folded over section? A friend of mine in my club has a repro to install and it has such a fold. Frankly I don't see the purpose of it but I wonder if they had originally.
Thanks
Randy
ekamm
ekamm
I can't tell that there is any fold over. I made a copy of it out of hard board and it fits snugly. Here are a couple of closeups of the lower part.
TR4nut
Sure doesn't look like a fold was there, thanks!
Edit: Light bulb finally came on, I think I know what might be going on with the repro one - probably not a folded section just extra length that can be cut off - maybe to accommodate both pre and post 60K cars.
ekamm
ekamm
If you're talking about that hole in the last pic above it's just one of the torn out hole from 50 years of use. The harness goes through at the corner and just passes through under the board.
Beer02
I am posting this message to several threads. If anyone can provide a pattern for the trunk (boot) closeout panel, I would be extremely grateful. If you would be willing to help me out, please respond, we can get in touch. Thanks in advance for any help.
6TTR3A
Keystonâ„¢ used to sell it by the yard. Take a look at :
https://www.keystonbros.com/subcategory-listing-page?cat_id=243835&grand_id=9274
Frank
G Wanted Tr4a boot lid Triumph Classifieds 2
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
AUSMHLY Boot Lid Identification Austin Healey 2
J Restoration Progress - Boot Installed Austin Healey 1
B BJ7 Boot Trim Austin Healey 7
B Fitting the Boot Lid Seal Austin Healey 8
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
chicken Boot Lid Badge Austin Healey 8
F TR2/3/3A Boot floor Triumph 50
steveg TR6 Dealing with Rack Boot Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
T How do you cover your battery in the boot? Austin Healey 5
S Securing the jack with strap in BJ8 boot Austin Healey 11
Michael Oritt Boot floorboard? Austin Healey 9
S Boot Liner - BJ8 Austin Healey 19
C Under boot and under bonnet paint? Austin Healey 7
tahoe healey Leak into boot Austin Healey 17
B TR6 Boot lid thread plates loose in stiffener Triumph 1
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
B Soft Top Boot Cover - BJ7 Austin Healey 5
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
ckeithjordan TR2/3/3A Boot Trim Triumph 3
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
B Dynamat in Boot? Austin Healey 7
S TR4/4A Fascia support and shift rod boot Triumph 0
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
CJD TR2/3/3A Boot Seal Pics Triumph 17
J BJ8 boot rubber strip Austin Healey 9
CJD TR2/3/3A TR2 Boot Strip Triumph 22
K TR4/4A TR4A vinyl top boot cover factory markings??? Triumph 0
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Rut TR4/4A Boot and bonnet bodywork. Triumph 4
D boot rubber ??? Austin Healey 2
Rut TR4/4A Parts in boot Triumph 11
SASSAMON TR2/3/3A TR3 Boot Construction Info Wanted Triumph 2
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
R Boot hinge support brackets for BJ8 MKIII Austin Healey 4
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
Rut Top frame and boot panels Spridgets 2
