TR2/3/3A tr3 valve cover gasket
mrv8q
Hello, listers, is gasket treatment necessary for the valve cover gasket. Permatex variations, honey ranch, bleu cheese, or naked cork? Thanks for the responses!
Banjo
I like a little gasket adhesive to stick mine to the cover. it keeps it in place while installing it and keeps it from "walking" while in use.
I only spray one side so it comes off clean with the cover, and I can get a couple of uses out of it.
Alan_Myers
Hi,
I like to soak the cork gasket in water for at least half an hour before installing, to help it form to the shape of the cover. Then I use a thin application of Hylomar on both surfaces. It's usually not possible to remove and reuse, but it also generally doesn't leak.
Someone named Justin used to make great silicon rubber gaskets for stock TR 4-cyl. valve covers. They cost more but seal great without any sort of sealant, plus can be used over and over. If you are interested, hopefully someone here can provide a means of getting in touch with Justin. I highly recommend his gaskets, but can't unfortunately haven't been able to use them on my car ever since I installed an aftermarket cast alloy valve cover. They only work with the original type of cover.
Cheers,
Alan
Geo Hahn
I use Permatex Hylomar HPF and it doesn't leak or want to squirt out along the sides... though an adhesive on the cover side is a reasonable thing.
There is a silicone gasket available. I have not used it but have heard nothing but favorable comments about it:
https://www.jmwagnersales.com/T4SiliconeGasket.htm
PS - That link is the Justin (Wagner) that Alan mentions.
mrv8q
mrv8q
Thanks, guys, that's exactly what I need, I'll call Jim during the week...many thanks!
StevenNewell
Definitely call *Justin*. I've been using his silicon gasket for a couple years. Makes routine valve adjustments a little easier. I had my car in a Brit restoration shop after hitting a Ford Exploder and the mechanic raved about the gasket -- he said he was going to order a bunch for his customers to make his job easier.
B TR4/4A TR3 valve cover on TR4A Triumph 4
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
J TR2/3/3A Need original valve cover 58 TR3 Triumph 4
K TR2/3/3A Valve cover install TR3. Triumph 4
Twosheds TR2/3/3A TR3 Valve Cover Triumph 24
F TR2/3/3A TR3 "NonBreather" Alloy Valve Cover Triumph 3
mcguijo TR2/3/3A Cast Aluminum Valve Cover TR3 Triumph 5
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
JFeher TR2/3/3A Installing valve guide seals on 59 TR3 Triumph 6
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
bertl TR2/3/3A TR3 Valve Train Pedestals Triumph 5
J TR2/3/3A Tr3-eary 4s, draft tube and /or PCV valve?? Triumph 13
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
K TR2/3/3A TR3 Brake Proportioning Valve? Triumph 2
B TR2/3/3A TR3 brake restrictor valve Triumph 6
ekamm TR2/3/3A Tr3 heater valve Triumph 12
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
prb51 TR2/3/3A TR3 valve clearance settings Triumph 10
M TR2/3/3A TR3 water valve Triumph 4
prb51 TR2/3/3A TR3 oil pressure relief valve Triumph 3
martx-5 TR2/3/3A TR3 Restrictor Valve Triumph 12
T TR2/3/3A TR3 pressure relief valve setting Triumph 6
TRclassic3 TR2/3/3A TR3 Valve Adjustment Triumph 10
K TR2/3/3A Valve gaps...fast road cam...TR3 Triumph 6
K TR2/3/3A TR3...Mild street cam....valve gap? Triumph 8
D TR2/3/3A TR3 Valve noise Triumph 4
