TR2/3/3A Cast Aluminum Valve Cover TR3
mcguijo
Was there a factory option for a cast aluminum valve cover on TR3? I can find the information on the engine sump but not valve cover. Seems like I remember reading one time that the al valve cover was an option but can't find reference.
Russ Austin
This was taken from TRA Judging Standards and Restoration Guidelines.
Cast Aluminum Valve Covers. According to The Roadster Factory, an aluminum cover was optional equipment.
SPCEd4, however, does not specify such as optional high speed equipment or as an accessory. Research on
accessories published in a VTR newsletter (ref: The Vintage Triumph Quarterly Magazine , pg 902) indicates that
while these might have been offered from the factory it could not be confirmed; however, such covers were
definitely dealer options. These covers will be accepted as original equipment.
mcguijo
mcguijo
Thanks for the response. I like the way the al valve cover look but probably won't like the price. Anyway, I have the original chrome cover at present. I received it back from getting re plated--chromed. To make a long story short, I'm guessing the valve cover was left to plate too long. The valve cover "cap" no longer fits (too small). I may just throw it out the window and get the al valve cover in place.
Russ Austin
I also like the look of the cast valve cover, the Triumph Tune I beleive is the Valve cover they are referring to.
Geo Hahn
[ QUOTE ]
...The valve cover "cap" no longer fits (too small). I may just throw it out the window and get the al valve cover in place.
[/ QUOTE ]
Those caps are often a snug fit, maybe a bit of light filing around the lip of the snout will let it go on. Otherwise, can I stand outside your window?
mcguijo
mcguijo
Actually I live in a one story house /ubbthreads/images/graemlins/laugh.gif Seriously though, let me look at the cost of these al valve covers. If I feel I don't have alot of costs to recover I could throw the old valve cover to AZ.
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
L How to repair cast aluminum transmission case Spridgets 26
G Cast Aluminum Oil Pan Austin Healey 16
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
JPSmit Interesting video - cast bakelite knobs Restoration & Tools 2
L The last cast iron 6 port head Austin Healey 9
PeterK Repairing cast iron manifold studs Triumph 16
T Back to original, cast iron header. Triumph 16
Hoosier MGB British Leyland cast logo placement on MGB MG 19
PatGalvin Valve Guides, Cast Iron Vs. Bronze Triumph 6
T cast iron welding info and repair-FYI Triumph 1
toysrrus "WANTED" Porsche 356A Speedster 1/18th Die-Cast: Other Cars 4
eschneider anyone have a cortina 1500 cast iron ex manifold Other British Cars 7
T TR4/4A Cast Iron Manifold TR 4A Triumph 2
MadRiver TR5/TR250 Still no sign of the die-cast TR-250? Triumph 0
A V12 block cast date * 1st post * Jaguar 6
David_K BJ8 Cast Iron Head Porting Austin Healey 16
MadRiver TR5/TR250 My TR-250 Wheels -- Cast your vote! Triumph 28
Whytock MGB Die Cast MGB Roadsters MG 8
Z BN1 Cast Iron Heads Austin Healey 2
M Naval Jelly used on cast iron Restoration & Tools 5
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
