TR2/3/3A TR3 heater valve is leaking like a sieve
Got_All_4
My TR3 heater valve is leaking like a sieve. You know the kind that looks like a house water valve. Any way to rebuild these?
Geo Hahn
I found an O-Ring that fit in mine (in lieu of the packing in there) and it has worked fine for years since.
Sorry, do not know what size but take it to Ace hardware where they have lots of little drawers of them.
This is assuming the leak is coming up and out around the stem.
<span style="font-style: italic">Thinking back... I may have actually stacked 2 O-rings in there to get the desired effect.</span>
angelfj1
. . . . . .most likely the valve stem packing (kinda like string)or a rubber seal or o-ring. Take it off and bring it to your local hardware store (local ma-pa type, not big box), they should be able to help.
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
ekamm TR2/3/3A Tr3 heater valve Triumph 12
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
parkerg1 TR2/3/3A TR3 Heater Triumph 10
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
M TR2/3/3A TR3 Heater Triumph 34
M TR2/3/3A TR3 heater install picture needed Triumph 33
Lukens TR2/3/3A Would you sell your TR3 heater? Triumph 18
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
Russ Austin TR2/3/3A Attempting to install a heater in my TR3 Triumph 39
M TR2/3/3A Heater removal in TR3 Triumph 13
H TR2/3/3A TR3 heater options Triumph 9
T TR2/3/3A TR3 heater pipe bracket Triumph 6
S TR2/3/3A Repairing a tr3 heater? Triumph 14
S TR2/3/3A tr3 heater Triumph 7
af3683 TR2/3/3A TR3 Heater Hoses Triumph 4
RedTR3 TR2/3/3A TR3 Heater Coolant Flow Direction Triumph 3
D TR2/3/3A TR3 heater reinstall problems Triumph 4
RedTR3 TR2/3/3A TR3 Heater Question Triumph 8
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
S TR2/3/3A Tr3 heater wirer Triumph 8
M_Pied_Lourd TR2/3/3A TR3 Heater Finish Triumph 8
S TR2/3/3A heater attaching piece tr3 Triumph 4
newmexTR3 TR2/3/3A TR3 heater hose install Triumph 4
Tinkerman TR2/3/3A Unknown Part TR3? Heater Bracket? Triumph 5
newmexTR3 TR2/3/3A tr3 heater vacuum lock? Triumph 2
S TR2/3/3A TR3 pipe leaking [housing to heater] Triumph 3
Got_All_4 TR2/3/3A My TR3 heater fan switch is broken Triumph 8
T TR4/4A TR3 / TR4 heater question Triumph 2
M TR2/3/3A TR3 Heater Core PSI Triumph 3
Geo Hahn TR2/3/3A TR3 Heater Alternatives Triumph 11
J Spitfire Spitfire heater upgrade to TR3? Triumph 7
PeterK TR2/3/3A TR3 heater part Triumph 0
