TR2/3/3A TR3 Smiths Heater Plate
luke44
My sandblaster messed up the id plate on my Smiths heater. While a repro plate is available, TRF will not stamp the new plate with the correct numbers. In my case the numbers as follows:
Code: HR2406 / 01
Model: R250
Voltage: 12
Anybody know where to get the numbers stamped? I really don't want to invest in a set of punches for a one-off usage.
Thanks in advance,
TR4nut
How about someone like a jeweler? I would think anyone with an engraving machine could fix you up pretty quickly.
Tinkerman
I have a 1/4 inch set of stamps and did my own. Ugly! I would guess a trophy company would be able to do it for you. Least wise that where I'm going to get my VIN number on my plate for the car. Not sure that they can stamp them though. Engraving is considerably different from stamping. Worth a shot though.
Let us know how you make out.
Tinkerman
PeterK
Harbor Freight sells 1/8" + 1/4" number punch sets: https://www.harborfreight.com/catalogsearch/result/?q=number+set
It does take some practice. I used aluminum flashing pieces from HD to practice on. Best result was clamping a piece of wood to act as a guide on the bottom. You'll have to practice on how hard to tap. I tried putting the practice plate on my cast iron table saw, on oak and maple wood and it's all different. I ended up using hard maple as the backing.
Make pencil marks on a piece of masking tape placed over and above the plate to mark the start of each letter. Keep the punch fully vertical to get an even impression. Tap lightly several times and don't move the punch until done.
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
R TR2/3/3A TR3 Wiper motor Triumph 10
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
5 TR2/3/3A TR3 fender patch panel question Triumph 10
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
