TR4/4A TR3 / TR4 heater question
TFR
Have a 1959 TR3 and the guy has installed a TR4 engine.
My question is when I tried to install the line that runs from the water pump housing (long tube shaped like a "L") the hole was smaller than the TR3.
What type of pipe or plumbing is installed into the TR4? Any pics would be great.
Thanks
TR3driver
Great Pumpkin - R.I.P
Larry, the water pump housing is the same ... sounds like you are missing the adapter for that line. Has pipe threads into the pump housing; and a reverse compression fitting for the line that runs along the engine. Sorry, don't recall the pipe thread size offhand, but it's smaller than 1/2" (which is the tubing size).
One alternative (not necessarily the best) is to find a pipe thread to hose barb adapter (at Home Depot, etc.) and just run 1/2" heater hose from there all the way to the firewall.
Randall
T
TFR
Thanks Randall... After you mention it I am missing the adapter. My car is in storage so I couldn't reference it,
Sorry for the dumb question...
Love this sight.
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
S TR2/3/3A Are a tr3 and tr4 radiators the same Triumph 3
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T TR2/3/3A TR4 Air cleaners on TR3 Triumph 7
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
K TR2/3/3A TR3 and TR4 Frame Width? Triumph 1
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
O TR2/3/3A TR4 overdrive in TR3 Triumph 4
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
O TR2/3/3A TR4 Wires to TR3 Triumph 11
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
K TR4/4A TR4/TR3 clutch operating shaft availability? Triumph 2
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
6 TR4/4A TR3 [TR4?] Generator available??? Triumph 10
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
Marvin Gruber TR4/4A Windshield motors TR3 & TR4 Triumph 2
M TR4/4A TR3 TR4 exhaust hanger question Triumph 4
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
TR4nut TR4/4A Differenc e between TR3 and TR4 lever shocks? Triumph 6
S TR4/4A late tr3 and tr4 gas caps Triumph 4
HerronScott TR4/4A TR3/TR4 tool roll on eBay? Triumph 3
M TR4/4A New TR3-TR4 RingTolerance Questions ???? Triumph 7
mountainman TR4/4A TR3 - Tr4 Temp Gauge Triumph 5
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
T TR6 TR6 seats fit into a TR3 or TR4? Triumph 10
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
T TR4/4A Corbeau seats in TR3 or TR4 Triumph 12
T TR4/4A TR3 or TR4 piston replacement question Triumph 2
T TR4/4A TR3 vs TR4 Radiator Triumph 2
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
