TR2/3/3A TR3 and TR4 Frame Width?
TR3driver
Great Pumpkin - R.I.P
Through most of the length of the TR4 frame, the frame itself was the same width. I'm not certain if the body mounting points were exactly the same, but the frame rails and so on were. The big difference was at the front suspension, where there were extra pieces welded to the outside of the frame rails, to increase the track by about 4" or so. The spring towers moved outward (onto the extensions) as did the motor mounts.
At the rear, the axle was wider, but the springs were exactly the same distance apart. I know because I once installed a TR4 axle in a 3A and didn't realize my mistake until I tried to insert the halfshafts from the 3A. The suspension bolted right up, and in fact I drove that way for several years (using the halfshafts from the TR4).
The 4A frame is completely different, not even a "ladder" design. They reworked the frame to accept the IRS; then modified that again to accept a solid rear axle (for solid axle 4As).
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
gsalt57tr3 TR4/4A TR3 on TR4 frame Triumph 5
V TR4/4A tr3 body on a tr4 frame Triumph 7
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
S TR2/3/3A Are a tr3 and tr4 radiators the same Triumph 3
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T TR2/3/3A TR4 Air cleaners on TR3 Triumph 7
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
O TR2/3/3A TR4 overdrive in TR3 Triumph 4
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
O TR2/3/3A TR4 Wires to TR3 Triumph 11
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
K TR4/4A TR4/TR3 clutch operating shaft availability? Triumph 2
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
6 TR4/4A TR3 [TR4?] Generator available??? Triumph 10
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
Marvin Gruber TR4/4A Windshield motors TR3 & TR4 Triumph 2
M TR4/4A TR3 TR4 exhaust hanger question Triumph 4
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
TR4nut TR4/4A Differenc e between TR3 and TR4 lever shocks? Triumph 6
S TR4/4A late tr3 and tr4 gas caps Triumph 4
HerronScott TR4/4A TR3/TR4 tool roll on eBay? Triumph 3
M TR4/4A New TR3-TR4 RingTolerance Questions ???? Triumph 7
mountainman TR4/4A TR3 - Tr4 Temp Gauge Triumph 5
T TR6 TR6 seats fit into a TR3 or TR4? Triumph 10
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
T TR4/4A Corbeau seats in TR3 or TR4 Triumph 12
T TR4/4A TR3 or TR4 piston replacement question Triumph 2
T TR4/4A TR3 vs TR4 Radiator Triumph 2
T TR4/4A TR3 / TR4 heater question Triumph 2
