TR2/3/3A TR3 Heater Finish
M_Pied_Lourd
Hi All,
Quick question. Although I am not a concourse guy, could you please tell me the correct finish on the bottom vents/bottom for a TR3 heater? I think that it might be a wrinkle finish but I am not sure.
Just working on the heater refurb now so thought I would ask before I paint.
Cheers,
M. Pied Lourd
TR4nut
Crinkle I think - Frank did a really nice writeup on this a while ago - I think it is in the BCF wiki?
Edit: yep, here it is: Heater Restoration
M_Pied_Lourd
M_Pied_Lourd
Thanks Randy,
Was looking at that earlier and actually sent Frank an email at the address on the Wiki page but it was undeliverable.
Looks kinda like a pebbly appearance in Franks photos...I have an idea what I am going to do...won't tell you until I do it though cause you will think that I am nuts :smile:
Will post some pics in the "making progress thread in the next day or two (I hope)
Cheers,
M. Pied Lourd
M_Pied_Lourd
M_Pied_Lourd
Sorry Paul...no red :smile:
Cheers,
M. Pied Lourd
angelfj1
MP
Sorry about the email address. I changed ISP's to Verizon. You can contact me anytime at trtags@verizon.net.
The correct finish for the top and bottom covers is black crinkle outside surface , gloss back everywhere else. I used powder coat, but rattle can paint is fine.
Note: Don't put too much paint on the heater matrix (core) or it will limit heater function.
M_Pied_Lourd
M_Pied_Lourd
Hi Frank,
Thanks for the response.
Good to know. For the core I have a special Radiator Black from Eastwood that I will be using sparingly. I am going to use something a little different top and bottom bu I think that the effect will be ok. Will post some pics for critique when I am done :cooler:
Cheers,
M. Pied Lourd
angelfj1
M_Pied_Lourd said:
Hi Frank,
Cheers,
M. Pied Lourd
MP: I'm sure it will turn out great!
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
parkerg1 TR2/3/3A TR3 Heater Triumph 10
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
M TR2/3/3A TR3 Heater Triumph 34
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
M TR2/3/3A TR3 heater install picture needed Triumph 33
Lukens TR2/3/3A Would you sell your TR3 heater? Triumph 18
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
Russ Austin TR2/3/3A Attempting to install a heater in my TR3 Triumph 39
M TR2/3/3A Heater removal in TR3 Triumph 13
H TR2/3/3A TR3 heater options Triumph 9
ekamm TR2/3/3A Tr3 heater valve Triumph 12
T TR2/3/3A TR3 heater pipe bracket Triumph 6
S TR2/3/3A Repairing a tr3 heater? Triumph 14
S TR2/3/3A tr3 heater Triumph 7
af3683 TR2/3/3A TR3 Heater Hoses Triumph 4
RedTR3 TR2/3/3A TR3 Heater Coolant Flow Direction Triumph 3
D TR2/3/3A TR3 heater reinstall problems Triumph 4
RedTR3 TR2/3/3A TR3 Heater Question Triumph 8
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
S TR2/3/3A Tr3 heater wirer Triumph 8
S TR2/3/3A heater attaching piece tr3 Triumph 4
newmexTR3 TR2/3/3A TR3 heater hose install Triumph 4
Tinkerman TR2/3/3A Unknown Part TR3? Heater Bracket? Triumph 5
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
newmexTR3 TR2/3/3A tr3 heater vacuum lock? Triumph 2
S TR2/3/3A TR3 pipe leaking [housing to heater] Triumph 3
Got_All_4 TR2/3/3A My TR3 heater fan switch is broken Triumph 8
T TR4/4A TR3 / TR4 heater question Triumph 2
M TR2/3/3A TR3 Heater Core PSI Triumph 3
Geo Hahn TR2/3/3A TR3 Heater Alternatives Triumph 11
J Spitfire Spitfire heater upgrade to TR3? Triumph 7
PeterK TR2/3/3A TR3 heater part Triumph 0
